Warning message
EJBQL DB Keys -> Oracle DB Tables
Jan 16th, 2014
Q: Cisco Prime Infrastructure 2.0 - CLI Template with DB Variables;
I'm working on a CLI template with DB variables and looking for a translation table between the EJBQL DB keys that are used in the CLI template and the real Oracle Table names (which seems to be different)
I can't find such information in the regular CPI docs i.e. cisco.com
thanks in advance for your kind help!
maxime.gerges Thu, 02/06/2014 - 08:35
I also want to work with DB keys and if possible customized DB keys.
Do you have some documentation on how to use those DB keys and what output what come from those on ?
Basically what I want to do is to test de device type and launch some personalized command according to it : set a local admin account on IOS and NXOS devices using the same template but with a test case on the device type
vergeerf Thu, 02/06/2014 - 09:27
No I don't have this information (yet) Cisco doesn't want to share this :-(
However to solve the problem you describe, you don't need to use DB variables in your Prime Infrastructure template. Simply create a user defined group for either/or IOS and NXOS devices and use that same device group in your template deployment (or design a CLI template specificaly for this type type as additional critera)
Kind Regards,
Frank
Related Content
