01-16-2014 09:49 AM - edited 03-18-2019 02:26 AM
We currently only have all our VoIP phones going to the Publisher because we are unable to get the Pub and Sub to talk to each other. We are trying to get our one Sub we have up to work and then stand up 2 more. I am just wondering what all can cause this issue or if anyone has had simliar troubles?
01-16-2014 10:11 AM
Start by checking the replication, also try a cluster reboot.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
01-16-2014 11:13 AM
It is not replicating.
01-16-2014 12:15 PM
Is the sub added on the pub with the correct admin and security password?
What version of cucm do u run?
01-16-2014 12:49 PM
Verified the password is correct and we run ver. 8.6.1.20009-3
01-16-2014 01:42 PM
So from cli via ssh you can login and ping each other?
Screenshot of your cluster setup please
