Warning message
Logging disk utilization is high
Answered Question
Jan 16th, 2014
in WSA system status, logging disk utilization showing as more than 90%. Kindly suggest how can i delete the old files from WSA??
Correct Answer by donnylee about 3 years 7 months ago
Did you keep high number of log files or oversized log files?
You can confirm this from the log subscriptions in the GUI menu.
You can make more room for logging by exporting the current logs using FTP, or delete the old logs.
Make sure you allow FTP access to the management interface.
Hope this helps.
- donny
Overall Rating: 5 (1 ratings)
Correct Answer
donnylee Sat, 01/18/2014 - 19:48
  • Cisco Employee,
Hope this helps.
- donny
