Warning message
why would trunk port go in "err-disabled"? bpduguard isn't configured for this port.
Endorsed Question
Jan 16th, 2014
why would trunk port go in "err-disabled"? bpduguard isn't configured for this port. following is the port info.
sw#sh run int TenGigabitEthernet3/2
Building configuration...
Current configuration : 203 bytes
interface TenGigabitEthernet3/2
switchport
switchport trunk allowed vlan 35-37, 42, 43
switchport mode trunk
no ip address
end
sw#sh int TenGigabitEthernet3/2
TenGigabitEthernet3/2 is down, line protocol is down (err-disabled)
  Hardware is C6k 10000Mb 802.3, address is b0fa.eb0f.3e84 (bia b0fa.eb0f.3e84)
  Description: UCS
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Cisco Endorsed by shulipal
Markus Schwarz about 3 years 7 months ago
Hello Gavin,
Before you go out and start replacing things, please have a log in your buffer. Lets see if you have a log entry still on your device which provides a clue as to why this port went down . (I assume it went down recently)
show log | i TenGigabitEthernet3/2
Have a log if you see anything.
If you dont have a log entry, please go to the affected interface and perform a shut and after a few seconds a no shut to see if the port comes up again.
I assume it will stay up for a short period and then retrun into err-disable state based on your recent statement. In any case, i hope that the    show log | i TenGigabitEthernet3/2
marQes
Overall Rating: 5 (2 ratings)
Markus Schwarz Thu, 01/16/2014 - 13:08
Hello Gavin,
I have come across this problem a few times in the past. Most of my problems were encountered during install activies as I kept constantly disconnecting and moving the GBICs in and out but of course there are other reasons:
There are various reasons for the interface to go into errdisable. The reason can be:
  • Duplex mismatch
  • Port channel misconfiguration
  • BPDU guard violation
  • UniDirectional Link Detection (UDLD) condition
  • Late-collision detection
  • Link-flap detection
  • Security violation
  • Port Aggregation Protocol (PAgP) flap
  • Layer 2 Tunneling Protocol (L2TP) guard
  • DHCP snooping rate-limit
  • Incorrect GBIC / Small Form-Factor Pluggable (SFP) module or cable
  • Address Resolution Protocol (ARP) inspection
  • Inline power
The most common reason (for me anyhow) was donw to cable and GBIC so I assume this would be the best place to start.
Hope that helps
Regads
marQes
Leo Laohoo Thu, 01/16/2014 - 13:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The answer to this question is the command "sh interface status err".
Markus Schwarz Thu, 01/16/2014 - 13:16
Hello Gavin,
marQes
