Warning message
LMS Prime Java Patches
Jan 16th, 2014
Does anyone know if there are plans to develop a LMS Prime 4.2 software patch    for   the recent  Java  client updates? Not surprisingly our Topoogy Services feature doesn't work  with client side Java patches applied
AFROJ AHMAD Thu, 01/16/2014 - 19:59
  • Cisco Employee,
Hi ,
what is the Java plug-in you are using ?
with LMS 4.2 topology will  work Only with "Java Plug-in version 1.6.0_24 or later update versions only"
Thanks-
Afroz
[Do rate the useful post]
syekhali Mon, 01/20/2014 - 11:54
Hi Bryan,
Uninstall Java from your client machine, Launch topology on the client machine and let LMS decide the best version. It would choose the version as suggested by Afroj and then hopefully you would be able to launch topology at your client site.
Get back in case you still are facing problems.
Syed Khalid
bryantsteve Wed, 01/22/2014 - 07:44
OK  thanks for the input, for now we set up to bypass the patched secure version of Java for the  LMS application on the client  side and use the  Java 6 version, not really what I was hoping for
