Warning message
Migrating from CM 6.1.3 to CM 9.X
Jan 16th, 2014
Dear Team
1. We are migrating from CM 6.1.3.1000-16 to CM 9.X. I am using following path:
2. Backup the current CM 6.1.3.
3. Fresh Installed CM 6.1.3.1000-16 on the VM machine
4. Restore the old CM 6.1.3 backup on fresh CM 6.1.3.1000-16 in VM.
5. Upload the licenses.
6. Upgrade to CM 6.1.5
7. Upgrading direct from CM 6.1.5 to CM 9.X.
Anyone can please answer, is this path is correct?
Overall Rating: 5 (3 ratings)
Manish Gogna Thu, 01/16/2014 - 19:02
  • Cisco Employee,
So basically the process would be:
Upgrade to version 6.1.4 or 6.1.5 on MCS
DRS Backup
Build same version of 6.1.4 or 6.1.5 on UCS
Restore the Backup
Upgrade to 9.x
Manish
Manish Gogna Thu, 01/16/2014 - 19:43
  • Cisco Employee,
Nice link for those who are not aware about the various D29 options [+5].
Manish
waqas sardar Fri, 01/17/2014 - 00:14
@ Manish
I already fresh installed 6.1.3 on the UCS and its working fine .
What are  the issues if i continous the same path?
Manish Gogna Fri, 01/17/2014 - 00:19
  • Cisco Employee,
Hi Waqas,
Installing cucm 6.1.3 on vmware is not TAC or BU supported as it has not been tested. Even if it works fine, TAC or BU will not support this installation as per the documentation which clearly says that only 6.1.4 or 6.1.5 ( or 7.1.3 / 5 ) can be used on vmware for jump upgrade to 9.x. So, i would suggest upgrading to 6.1.4 on MCS first and then restoring its backup on a freshly built 6.1.4 on vmware so that your installation is TAC and BU supported.
Manish
waqas sardar Tue, 01/21/2014 - 10:44
I can only restore backup on publisher and then reinstall subcriber ?
waqas sardar Wed, 01/22/2014 - 03:14
@ Jaime Valencia
2. upgrade the current CM 6.1.3 to CM 6.1.5 on MCS  and DRS.
3. Fresh Installed CM 6.1.5 on the VM machine.(6.1.5 is VM supported  ? )
4. Restore the old CM 6.1.5 backup on fresh CM 6.1.5 in VM.
5. Upgrading direct from CM 6.1.5 to CM 9.X.
Aman Soi Wed, 01/22/2014 - 03:21
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi Waqas,
all points are  correct.
for point 5, u need to have cop files uploaded in call manager servers, depending on you are upgrading to restricted or unrestricted version of 9.x
regds,
aman
waqas sardar Wed, 01/29/2014 - 08:33
I have tried jump upgrade but Pub crashed every time by following error
*** An error occurred during the file system check.
*** Dropping you to a shell; the system will reboot
*** when you leave the shell.
Give root password for maintenance
(or type Control-D to continue):
cisco tac said its bug:
https://tools.cisco.com/bugsearch/bug/CSCui85967
NTP is configurered perfectly and also checked by command utile diagnose test.
how can get the complete traces n logs during the upgrdation process.
Aman Soi Wed, 01/29/2014 - 18:36
    2017 IP Telephony
Hi Rob,
thanks for sharing the bug[+5]
regds,
aman
Mark Lyman Wed, 01/29/2014 - 14:05
This occurs when you dont specify an NTP server in the 6.1.5 VM.  When you jump it to 9.1.2, it errors out.  Specify an NTP server in the 6.1.5 VM before you do the jump.
Also, you missed a step at the end where you have to build a fresh 9.1.2 VM and DRS from the "jumped" 9.1.2 to the fresh one.  This is because the 6.1.5 VM does not support VM and it causes a partition misalignment, which you will see in the 9.1.2 gui.
