01-17-2014 01:14 AM - edited 03-07-2019 05:37 PM
I have connected a Switch type WS- C3560CPD - 8PT -S. The problem is that I do not get gig ports 0 / 1 to 8 to be working. I have power on port 9 and 10 and they seem to trunk . The switch responds to IP, but even if I connect to a PC on port Provide 0 /1 then I get notconnect on the ports
I have changed cables and assured me that the port is config similar to other switches .
Do I need an external power supply to the switch or is there a command to get the ports to work as normal.
Cofig on the port now looks like this :
interface GigabitEthernet0 / 1
switchport access vlan 500
switchport mode access
switchport voice vlan 700
no logging event link- status
no snmp trap link- status
storm -control broadcast level 3.00
spanning -tree PortFast
spanning -tree bpduguard enable
end
There are no error messages with sh log:
000014 : * March 1 01:00:41.481 GMT : % SNMP -5 - COLD START : SNMP agent on host 12s - sw - evenfe - 3560 is undergoing a cold start
000015 : * March 1 01:00:41.502 GMT : % SSH -5 - ENABLED : SSH 1.99 has been enabled
000016 : * March 1 01:00:42.016 GMT : % SYS -6 - LOGGINGHOST_STARTSTOP : Logging two host 146.2.76.74 Port 514 started - CLI initiated
000017 : * March 1 01:00:43.012 GMT : % LINK -3 - UPDOWN : Interface GigabitEthernet0/10 , changed state two up
000018 : * March 1 01:00:45.807 GMT : % SPAN TREE -5 - CHANGE ROOT : Root Changed for VLAN 500: New Root Port is GigabitEthernet0/10 . New Root Mac Address is 0008.30ab.3180
000019 : * March 1 01:00:45.812 GMT : % SPAN TREE -5 - TOPOTRAP : Topology Change Trap for VLAN 500
000020 : * March 1 01:00:45.823 GMT : % LINEPROTO -5 - UPDOWN : Line protocol on Interface Vlan799 , changed state two up
000021 : . Jan. 17 10:02:59.767 GMT : % CDP_PD -2 - POWER_LOW : 15.4 W power - Negotiated WS- C3560 - 8PC ( 0008.30ab.3182 ) on port Gi0/10
000022 : . Jan. 17 10:02:59.788 GMT : % LINEPROTO -5 - UPDOWN : Line protocol on Interface GigabitEthernet0/10 , changed state two up
000023 : . Jan. 17 10:03:00.118 GMT : % LINK -3 - UPDOWN : Interface GigabitEthernet0 / 9, changed state two up
000024 : Jan 17 10:03:00.768 GMT : % CDP_PD -2 - POWER_LOW : 15.4 W power - Negotiated WS- C3560 - 8PC ( 0008.30ab.3182 ) on port Gi0/10
000025 : Jan 17 10:03:02.126 GMT : % LINEPROTO -5 - UPDOWN : Line protocol on Interface GigabitEthernet0 / 9, changed state two up
000026 : Jan 17 10:03:02.158 GMT : % CDP_PD -2 - POWER_LOW : 15.4 W power - Negotiated WS- C3560 - 8PC ( 0008.30ab.3183 ) on port Gi0 / 9
000027 : Jan 17 10:03:03.159 GMT : % CDP_PD -2 - POWER_LOW : 15.4 W power - Negotiated WS- C3560 - 8PC ( 0008.30ab.3183 ) on port Gi0 / 9
000028 : Jan 17 10:05:29.402 GMT : % SEC_LOGIN -5 - LOGIN_SUCCESS : Login Success [user : jenssk ] [ Source : 146.2.76.82 ] [ local port : 23] at 10:05:29 GMT Fri January 17 2014
Regards Jens
01-17-2014 02:51 AM
Please post the output to the following commands:
1. sh version
2. sh power inline
01-17-2014 03:12 AM
Sh Version
Cisco IOS Software, C3560C Software (C3560c405ex-UNIVERSALK9-M), Version 12.2(55)EX2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 18-May-11 15:35 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3560C boot loader
BOOTLDR: C3560C Boot Loader (C3560C-HBOOT-M) Version 12.2(55r)EX11, RELEASE SOFTWARE (fc1)
12s-sw-evenfe-3560 uptime is 1 hour, 17 minutes
System restarted at 10:50:53 CET Fri Jan 17 2014
System image file is "flash:/c3560c405ex-universalk9-mz.122-55.EX2/c3560c405ex-universalk9-mz.122-55.EX2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560CPD-8PT-S (PowerPC) processor (revision C0) with 131072K bytes of memory.
Processor board ID FOC1643Y3N5
Last reset from power-on
2 Virtual Ethernet interfaces
10 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 58:97:1E:D1:10:00
Motherboard assembly number : 73-13273-06
Motherboard serial number : FOC16422W2A
Model revision number : C0
Motherboard revision number : A0
Model number : WS-C3560CPD-8PT-S
System serial number : FOC1643Y3N5
Top Assembly Part Number : 800-33671-02
Top Assembly Revision Number : A0
Version ID : V02
CLEI Code Number : CMMEA10BRB
Hardware Board Revision Number : 0x00
Switch Ports Model SW Version SW Image
* 1 10 WS-C3560CPD-8PT-S 12.2(55)EX2 C3560c405ex-UNIVERSALK9-M
Configuration register is 0xF
And Sh Power Inline
12s-sw-evenfe-3560#sh power inline
Available:0.0(w) Used:0.0(w) Remaining:0.0(w)
Interface Admin Oper Power Device Class Max
(Watts)
Gi0/1 auto off 0.0 n/a n/a 30.0
Gi0/2 auto off 0.0 n/a n/a 30.0
Gi0/3 auto off 0.0 n/a n/a 30.0
Gi0/4 auto off 0.0 n/a n/a 30.0
Gi0/5 auto off 0.0 n/a n/a 30.0
Gi0/6 auto off 0.0 n/a n/a 30.0
Gi0/7 auto off 0.0 n/a n/a 30.0
Gi0/8 auto off 0.0 n/a n/a 30.0
Jens
01-17-2014 04:29 PM
Ideally, this model would require a power feed of 20.0w (PoE+).
Your current power feed is only 15.4w PoE.
Documentation doesn't say what happens if you have 15.4w.
02-06-2021 05:16 AM
i have 2 cisco WS-C3560CPD-8PT-S Switches.
* 1 10 WS-C3560CPD-8PT-S 15.0(2)SE5 C3560c405ex-UNIVERSALK9-M
I have also an Linksys LAPAC1200 AccessPoint with PoE.
The AP works fine, also with another siwthc with PoE no Problem.
But with the Cisco Switch, it wont come up
Switch tells me:
Jun 16 23:11:50.508: %ILPOWER-7-DETECT: Interface Gi0/1: Power Device detected: IEEE PD
Jun 16 23:11:50.508: %ILPOWER-5-ILPOWER_POWER_DENY: Interface Gi0/1: inline power denied. Reason: Insufficient total available power
SW03_DG#sh pow inline
Available:15.4(w) Used:15.0(w) Remaining:0.4(w)
(Watts)
Can anybody help me?
Also a PoE Door Bell has the same problem, with the same message.
The other switch is the same.
These devices never consume more than 15W.
Whats the reason, and how can i get the devices run?
Thanks.
