UCCx get digit string to dial a particular ext range
Jan 17th, 2014
I am currently using combination if Get Digit String step and Switch string step to dial an extension at anytime.
Customer wants the dial by extension option to be set so that it can only dial extensions in the 4XXX range only.
No other range should be dialed.
Thanks.
Overall Rating: 4.5 (2 ratings)
Hermanus Janse ... Fri, 01/17/2014 - 03:48
  • Silver, 250 points or more
you can maybe add an IF/else statement in your script saying if ext = 4XXX transfer else play prompt.
Chris Deren Fri, 01/17/2014 - 06:40
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
+5 to Hermanus Janse
You can simply check the DN range, assume the get digit is a string defined as strDigits, you would do:
if getDigit.length = 4 AND getDigit.substring(0)==4 then
     Route
else
     Do whatever
HTH,
Chris
