Warning message
WLC 5508 (7.6.100.0) - AP invalidates primary/backup image after reboot
Jan 17th, 2014
I'm running 7.6.100.0 as default in production and wants wlc to boot with 7.5.102.0 if I run into issues regarding the 7.6.100.0.
To prepare I have predownloaded the backup image into all AP's.
However, if one AP reboots while the WLCis still running 7.6.100.0 the AP has an invalid primary image and need to re-download 7.6.100.0.
The backup image is then displayed as "3.0.51.0".
If someone reboots the AP, the reboot time is much longer than usually.
And the download might be an issue for some offices in Middle-East and Asia, since the WLC i located in Europe.
Due to some small VPN internet access lines.
This is something that came with version 7.6.100.0.
Before I upgraded the WLC, I was running 7.5.102.0 as primary and 7.3.112.0 as backup, with no issues regarding reboots and image.
Have anyone encounter this type of problem?
Any tips to solve this is much appreciated.
//Jan-Erik
Overall Rating: 4 (3 ratings)
Scott Fella Sat, 01/18/2014 - 06:35
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I haven't seen this with the newer model access points as I use the pre-download prior to rebooting the WLC to a new code. I currently have WLC's running older code with a newer code define as not active, not default on the WLC but defined as backup image on the access point. I have also rebooted some AP's to make sure that nothing happens during a reboot.
One thing you can do is pre-download the new image and telnet or ssh to the access point and login and look at the flash you should see the image. You can also look at the primary and backup image from the WLC CLI also, but I would look at the AP. If the image is there, I would probably reboot the AP and look at the flash again and see if the image is there or not. Hard to say why it happens, but you would have to dig around to see if a particular AP or maybe AP model. Also see if there is enough flash memory on the AP's and the AP's might be crashing and that's why you are saying the AP's disappear and comes back with a default backup image. There is an issue we are tracking with v7.5 and AP's silent crashing.
panayiotiscy Wed, 07/02/2014 - 05:34
hello all,
as we are also bumping into this problem, is there any suggested workaround?
thanks
Jan-Erik Eikefjord Mon, 01/20/2014 - 12:12
Thanks, Fella for you feedback!
UPDATE
First of all I have narrow it down and found out that the 1130,1140, 1240 and 1250 are OK
AIR-LAP1131AG-E-K9 reboots and starts with prim: 7.6.100.0 backup: 7.5.102.0 status; OK
AIR-LAP1142N-E-K9  reboots and starts with prim: 7.6.100.0 backup: 7.5.102.0 status; OK
AIR-LAP1242AG-E-K9 reboots and starts with prim: 7.6.100.0 backup: 7.5.102.0 status; OK
AIR-LAP1252AG-T-K9 reboots and starts with prim: 7.6.100.0 backup: 7.5.102.0 status; OK
It seems to be related to the 2602 and 3602 series.
Let me described the steps I did to pinpoint these two models.
AIR-CAP2602I-E-K9
1. New-out-of-the-box and runs prim: 7.3.1.73 backup: 0.0.0.0;
2. Self-upgrade prim: 7.6.100.0 backup: 3.0.51.0.  status; Downloading
3. reboots and starts with prim: 7.6.100.0 backup: 3.0.51.0.
4. Manual upgrade / predownloading backup to; 7.5.102.0
5. rebooting from wlc with prim: 7.6.100.0, backup: 7.5.102.0 -comment; starts up with 7.5.1.73 and does the downloading of prim image. Backup: 0.0.0.0
6. self-reboot after downloading, prim: 7.6.100.0. Comes up with prim: 7.6.100.0 backup: 3.0.51.0.
7. reboots from wlc/manual with prim: 7.6.100.0 backup: 3.0.51.0. -comment; no change, comes up with prim: 7.6.100.0 backup: 3.0.51.0.
AIR-CAP3602E-E-K9
1. reboots from WLC and manual with prim: 7.6.100.0, backup: 3.0.51.0 - comment; no problem, comes online with 7.6.100.0/3.0.51.0.
2. Manual upgrade / predownloading backup to; 7.5.102.0
3. rebooting from wlc with prim: 7.6.100.0, backup: 7.5.102.0 -comment; starts up with 7.3.1.73 and does the downloading of prim image. Backup: 0.0.0.0
4. self-reboot after downloading, prim: 7.6.100.0. Comes up with prim: 7.6.100.0 backup: 3.0.51.0.
5. reboots from wlc/manual with prim: 7.6.100.0 backup: 3.0.51.0. -comment; no change, comes up with prim: 7.6.100.0 backup: 3.0.51.0.
During upgrade it gives out this message;
*Jan 20 15:27:29.927: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
Image 7.5.102.0 not found in flash, predownloading.
examining image...
extracting info (286 bytes)
Image info:
    Version Suffix: k9w8-.152-4.JA1
    Image Name: ap3g2-k9w8-mx.152-4.JA1
    Version Directory: ap3g2-k9w8-mx.152-4.JA1
    Ios Image Size: 758272
    Total Image Size: 11520512
    Image Feature: WIRELESS LAN|LWAPP
    Image Family: AP3G2
    Wireless Switch Management Version: 7.5.102.0
Not enough free space to download.
Check for crashinfo/radio coredump and non used image files...
Not enough free space to download image first w/o extracting
deleting existing version(s)...
Deleting current version: flash:/ap3g2-k9w8-mx.152-4.JB3...
Set booting path to recovery image: 'flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx'...done.
Extracting files...
ap3g2-k9w8-mx.152-4.JA1/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/img_sign_rel_sha2.cert (1371 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/B5.bin (1816 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/V5.bin (525 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/img_sign_rel.cert (1375 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/Y5.bin (1524 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/file_hashes (5001 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/B2.bin (9328 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/X5.bin (1487 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/final_hash.sig (513 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/final_hash (141 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/info (286 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/E5.bin (1803 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/Y2.bin (5830 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/V2.bin (12826 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/ap3g2-k9w8-mx.152-4.JA1 (206045 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/8004.img (541961 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/E2.bin (18656 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/ap3g2-k9w8-xx.152-4.JA1 (10519307 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/X2.bin (15158 bytes)
ap3g2-k9w8-mx.152-4.JA1/html/ (directory) 0 (bytes)
ap3g2-k9w8-mx.152-4.JA1/html/level/ (directory) 0 (bytes)
ap3g2-k9w8-mx.152-4.JA1/html/level/1/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/back.shtml (512 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/sitewide.js (16560 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/officeExtendap.css (41801 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/ap_home.shtml.gz (1297 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/appsui.js (563 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/config.js (25812 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/forms.js (20125 bytes)
ap3g2-k9w8-mx.152-4.JA1/html/level/1/images/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/images/cisco-logo-2007.gif (1648 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/images/info.gif (399 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/images/background_web41.jpg (732 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/1/images/login_homeap.gif (19671 bytes)
ap3g2-k9w8-mx.152-4.JA1/html/level/15/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/15/officeExtendapSummary.htm (718 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/15/officeExtendapEvent.shtml.gz (988 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/15/officeExtendapMain.shtml.gz (3350 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/15/officeExtendapBanner.htm (7114 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/15/officeExtendapConfig.shtml.gz (2864 bytes)
extracting ap3g2-k9w8-mx.152-4.JA1/html/level/15/officeExtendapHelp.htm (5013 bytes)
extracting info.ver (286 bytes)
New software image installed in flash:/ap3g2-k9w8-mx.152-4.JA1
archive download: takes 251 seconds
New backup software image installed in flash:/ap3g2-k9w8-mx.152-4.JA1/ap3g2-k9w8-mx.152-4.JA1
Reading backup version from flash:/ap3g2-k9w8-mx.152-4.JA1/ap3g2-k9w8-mx.152-4.JA1done.
Writing out the event log to flash:/event.log ...
THEN IT BOOTS ON 7.6.100.0
*Mar  1 00:00:57.047: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
examining image...
Image info:
    Version Suffix: k9w8-.152-4.JB3
    Image Name: ap3g2-k9w8-mx.152-4.JB3
    Version Directory: ap3g2-k9w8-mx.152-4.JB3
    Ios Image Size: 215552
    Total Image Size: 13660672
    Image Family: AP3G2
    Wireless Switch Management Version: 7.6.100.0
Deleting flash:/ap3g2-k9w8-mx.152-4.JA1
*Mar  1 00:01:07.051: %CAPWAP-3-ERRORLOG: Selected MWAR 'krs-wlc-ha.elkem.com'(index 0).
*Mar  1 00:01:07.051: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 20 15:37:13.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 144.127.abc.abc peer_port: 5246
*Jan 20 15:37:13.471: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 144.127.abc.abcpeer_port: 5246
*Jan 20 15:37:13.471: %CAPWAP-5-SENDJOIN: sending Join Request to 144.127.abc.abc
*Jan 20 15:37:13.475: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jan 20 15:37:13.475: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jan 20 15:37:13.475: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jan 20 15:37:13.475: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 144.127.abc.abcperform archive download capwap:/ap3g2 tar file done (free up 11507200 bytes)
Extracting files...
ap3g2-k9w8-mx.152-4.JB3/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/V2.bin (12826 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/Y2.bin (5830 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/file_hashes (6108 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/8004.img (553576 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/X5.bin (1519 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/final_hash.sig (513 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/ap3g2-k9w8-tx.152-4.JB3 (73 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/ap3g2-k9w8-xx.152-4.JB3 (12049578 bytes)
*Jan 20 15:39:13.679: %CAPWAP-3-ERRORLOG: Invalid event 48 & state 10 combination.
*Jan 20 15:39:13.679: %CAPWAP-3-ERRORLOG: SM handler: Failed to process timer message. Event 48, state 10
*Jan 20 15:39:13.679: %CAPWAP-3-ERRORLOG: Failed to handle timer message.
*Jan 20 15:39:13.679: %CAPWAP-3-ERRORLOG: Failed to process timer message.
extracting ap3g2-k9w8-mx.152-4.JB3/R5.bin (3406 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/R2.bin (9328 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/img_sign_rel_sha2.cert (1371 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/B2.bin (9328 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/info (286 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/8006.img (543804 bytes)
ap3g2-k9w8-mx.152-4.JB3/html/ (directory) 0 (bytes)
ap3g2-k9w8-mx.152-4.JB3/html/level/ (directory) 0 (bytes)
ap3g2-k9w8-mx.152-4.JB3/html/level/1/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/forms.js (20125 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/appsui.js (563 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/ap_home.shtml.gz (1297 bytes)
ap3g2-k9w8-mx.152-4.JB3/html/level/1/images/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/images/info.gif (399 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/images/cisco-logo-2007.gif (1648 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/images/background_web41.jpg (732 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/images/login_homeap.gif (19671 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/config.js (26330 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/sitewide.js (17089 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/officeExtendap.css (41801 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/1/back.shtml (512 bytes)
ap3g2-k9w8-mx.152-4.JB3/html/level/15/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/15/officeExtendapBanner.htm (7114 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/15/officeExtendapConfig.shtml.gz (2864 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/15/officeExtendapSummary.htm (718 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/15/officeExtendapHelp.htm (5013 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/15/officeExtendapMain.shtml.gz (3350 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/html/level/15/officeExtendapEvent.shtml.gz (988 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/B5.bin (1980 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/E5.bin (1816 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/Y5.bin (1544 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/C2.bin (19822 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/final_hash (141 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/C5.bin (6936 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/img_sign_rel.cert (1375 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/Q5.bin (2790 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/X2.bin (15158 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/E2.bin (18656 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/Q2.bin (5830 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/V5.bin (525 bytes)
extracting ap3g2-k9w8-mx.152-4.JB3/ap3g2-k9w8-mx.152-4.JB3 (207764 bytes)
New software image installed in flash:/ap3g2-k9w8-mx.152-4.JB3
Configuring system to use new image...done.
                                sh:/event.log ...
archive download: takes 295 seconds
*Jan 20 15:42:09.163: image upgrade successfully, system is now reloading
*Jan 20 15:42:09.215: %SYS-5-RELOAD: Reload requested by capwap image download proc. Reload Reason: NEW IMAGE DOWNLOAD.
*Jan 20 15:42:09.215: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
Write of event.log done
I have also tried to remove all the files on the AP, just leaving
Directory of flash:/
   58  -rwx         296  Jan 20 2014 18:33:37 +00:00  env_vars
   13  drwx         448   Dec 9 2013 23:30:23 +00:00  ap3g2-rcvk9w8-mx
Mike Kellner Sat, 03/22/2014 - 22:49
Hello, we will upgrade wlc 5508 from 7.4 to 7.6.100 with many new 2602E APs.
We see now the same space Problem.
Exists a official Cisco solution for this problem now?
Exists a working Workaround from your side?
Thanks Mike
Jan-Erik Eikefjord Mon, 03/31/2014 - 05:37
Hi, Mike
As fare as i know there is just not enough free space on the flash to hold two sets of images.
The people from TAC tried also to find a solution, but ended up sending me this information;
Starting with the Cisco IOS releases 15.2(4)JB and 12.4(25e)JAO, on Cisco Aironet 3600 series APs, the backup IOS image is deleted from the system board's Flash memory when the new image is downloaded on to it. This is designed to be so because the system board's Flash memory, which has a total of 31 MB, does not have enough space to store the recovery image, the new image, and the backup image.
We have 2 wlc + HA all with the same version, so if one wlc goes down all the ap wil move to another wlc and not need to do a download of image.
I'm looking forward to the release of 8.1 :)
Scott Fella Mon, 01/20/2014 - 13:00
  • Hall of Fame,
    2017 Wireless
Check the free space on the flash
Jan-Erik Eikefjord Mon, 01/20/2014 - 13:09
Do you know how can i free more space?
    2  -rwx       49168  Jan 20 2014 19:05:52 +00:00  lwapp_non_apspecific_reap.cfg
    3  drwx         128  Jan 20 2014 18:53:21 +00:00  configs
    4  -rwx         280  Jan 20 2014 19:05:47 +00:00  lwapp_officeextend.cfg
    5  -rwx       75097  Jan 20 2014 19:03:04 +00:00  event.log
    6  -rwx       95008  Jan 20 2014 19:05:54 +00:00  lwapp_reap.cfg
    7  drwx        1792  Jan 20 2014 19:02:57 +00:00  ap3g2-k9w8-mx.152-4.JB3
   58  -rwx        7192  Jan 20 2014 19:05:52 +00:00  private-multiple-fs
   59  -rwx         296  Jan 20 2014 19:05:44 +00:00  env_vars
31739904 bytes total (10656768 bytes free)
Scott Fella Mon, 01/20/2014 - 14:25
  • Hall of Fame,
    2017 Wireless
Well you have 10mb free. Is this AP office extend? What mode is this AP going to be as you can delete some of those files in flash if your not using it. Also you can remove the RCV image if you want. It's a small file though.
Jan-Erik Eikefjord Tue, 01/21/2014 - 00:07
I'm not running them as Office Extend.
AP mode is FlexConnect and everything else is basicly default.
Sandeep Choudhary Tue, 01/21/2014 - 00:50
  • Purple, 4500 points or more
    2017 Wireless
HI Jan,
As per your question, I can say that if AP dont have neoght memory then it show only the primary image:
just like it:
And U r talking about about Mini IOS: 3.0.51.0.
So dont worry about this.
AP will show only Primary Image.
Dont forget to rate helpful posts.
Sandeep Choudhary Tue, 01/21/2014 - 00:31
    2017 Wireless
HI Jan,
You can delete event log file, lwapp_officeextend.cfg,lwapp_non_apspecific_reap.cfg and lwapp_reap.cfg
Scott Fella Mon, 01/20/2014 - 14:28
  • Hall of Fame,
    2017 Wireless
I have both 2602 and 3602 in my lab and no issues. I can play around with it and see of I can replicate your issue.
Thomas McClintic Tue, 01/21/2014 - 10:05
I am replicating this issue. Running 7.6.100 as primary on WLC with 7.4.1.30 as backup.
Pushed backup image to APs, verified in WLC GUI.
Rebooted AP, AP states not enough space. Shows on version 7.5 on the WLC when it is downloading the 7.6 code and back up image of 3.0.51.0.
AP is in a DHCP scope with 7.2 WLCs as options, but HA configured on AP for the 7.6 WLC.
Thomas McClintic Tue, 01/21/2014 - 12:44
Here is from the bootloader
cisco AIR-CAP2602I-A-K9 (PowerPC) processor (revision A0) with 180214K/81920K bytes of memory.
Processor board ID FTX1742J277
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.5.1.73
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: C0:67:AF:6F:30:DB
Part Number                          : 73-14588-02
PCA Assembly Number                  : 800-37899-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC173512PB
Top Assembly Part Number             : 800-38356-01
Top Assembly Serial Number           : FTX1742J277
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP2602I-A-K9
% Please define a domain-name first.
I have never installed 7.5 on a WLC here. It would appear the LWAPP version is incorrectly marked, or something to that affect.
examining image...
Image info:
    Image Family: AP3G2
Deleting flash:/ap3g2-k9w8-mx.v152_2_jb.201310300019 examining image...
Image info:
    Image Family: AP3G2
Sandeep Choudhary Tue, 01/21/2014 - 12:54
    2017 Wireless
make it factory default(Delete k9w8 image) and upload it agian.
Then try to connect it gaian
Leo Laohoo Tue, 01/21/2014 - 13:31
  • Hall of Fame,
    2017 LAN, Wireless
Oh for goodness sake ...
You gents want to convert this to autonomous right?  Ok, here's a good two-step process which will wipe away your sweat and tears:
1.  Command:  format flash:
2.  Using a TFTP Server to Return to a Previous Release
Now, if you have an existing configuration and you want to maintain the config whilst re-installing the IOS, between step 1 and step 2, save the configuration using the "write" command.
Thomas McClintic Tue, 01/21/2014 - 14:00
No sir, this issue is two images primary/backup on the AP. Rebooting the AP and the AP requiring an 'upgrade' to join the controller.
Not looking for autonomous.
This bug basically tells us not to predownload backup versions on APs....
Scott Fella Tue, 01/21/2014 - 15:15
  • Hall of Fame,
    2017 Wireless
Im going to test this again... I'm adding a new 2602 and will bounce the AP and see what happens.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Scott Fella Tue, 01/21/2014 - 15:47
  • Hall of Fame,
    2017 Wireless
It's probably a bug with the 2602's.  You might want to open a TAC case and reference this thread.
I had the same issue with a 2602e, but not with any other AP types:  Below are outputs from a 2602e and a 3602i
(WLC2504) >show ap image AIR-CAP2602E-A-K9
Total number of APs.............................. 6
Number of APs
        Initiated....................................... 0
        Predownloading.................................. 0
        Completed predownloading........................ 1
        Not Supported................................... 1
        Failed to Predownload........................... 0
                                                 Predownload     Predownload                                  Flexconnect
AP Name            Primary Image  Backup Image   Status          Version        Next Retry Time  Retry Count  Predownload
AIR-CAP2602E-A-K9  7.6.100.0      7.5.102.0      Complete        7.5.102.0      NA               NA
(WLC2504) >
Number of APs
        Completed predownloading........................ 0
AIR-CAP2602E-A-K9  7.3.1.73       0.0.0.0        None            None           NA               NA
(WLC2504) >show ap image AIR-CAP3602I-A-K9-Beta
Number of APs
AIR-CAP3602I-A-K9-Beta 7.6.100.0      7.5.102.0      None            None           NA               NA
Total number of APs.............................. 5
Number of APs
Scott
Jan-Erik Eikefjord Tue, 02/04/2014 - 01:40
This is the reply from TAC on this matter;
Ref. http://tools.cisco.com/squish/b3090
Scott Fella Tue, 02/04/2014 - 03:53
  • Hall of Fame,
    2017 Wireless
Thanks for the follow up!
+5
Leo Laohoo Tue, 01/21/2014 - 15:16
  • Hall of Fame,
    2017 LAN, Wireless
What they want you to do is to force the WLC to give you a fresh image because the current FULL controller-based IOS your AP is using could be corrupt.
Now the issue is that there seems to be an issue loading the IOS.  You've got two choices to go over this hurdle:  The long way around the mountain (what you all are doing) or the nice-and-nasty way (format the flash, run the "mode" button and off you go to the next step).
patrick.kofler Mon, 02/03/2014 - 04:07
I have the same issue, but after some tests I think this cannot be easily remedied.
The 2600 Series has 32MB Flash. Each new AP has a recovery image pre-installed, which in that case, is about 7-8MB. So we only have 24MB left.
Checking on the bundle size on the WLC running 7.6 it states the following (command used is: show ap bundle all)
Primary AP Image        Size        (7.6.100.0)
ap1g1                   10876
ap1g2                   11356
ap1g3                   7672
ap3g1                   10248
ap3g2                   13380
ap3g3                   0
ap801                   7524
ap802                   8968
c1130                   5092
c1140                   10096
c1250                   7264
c1520                   8396
c602i                   3756
version.info                    4
Secondary AP Image      Size        (7.5.102.0)
ap1g1                   10776
ap1g2                   10116
ap3g1                   10156
ap3g2                   11276
ap801                   7444
ap802                   8848
c1130                   5092
c1140                   10008
c1250                   7184
c1520                   8288
c602i                   3756
The one marked in red is the image for the 2600. Subtract about 13.5MB from the remaining 24MB leaves 10.5MB. Definitely not enough for a backup image to be stored in the flash let alone to inflate it in case it would still succeed to be transferred. Additionally this output conforms with your observation that series 1130,1240 and 1250 work without any issues. There is enough space to fit both images as well as the recovery image. I assume that for the 1140 Series the flash is fitting just right .
So, in order to do what you wish is to ssh/telnet into every AP and remove the recovery image to free up enough space for both main images. I tried that on my test AP and it worked.
However, keep in mind that this might not be a solution endorsed by Cisco.
P.S.: If someone knows the equivalent command for showing the AP image sizes on the 5760 WLCs I would be very grateful.
Patrick
Scott Fella Mon, 02/03/2014 - 06:01
  • Hall of Fame,
    2017 Wireless
Removing files on flash is okay as long as you know what your doing:)  As far as the 5760, you can see the image size by looking at the flash:
dir flash:mnt/images/ap.bak
Scott
patrick.kofler Mon, 02/03/2014 - 23:42
I just remembered that this "workaround" will only, if you have not yet predownloaded the image to the APs yet. The reason is that after the download the WLC thinks that now its primary and secondary image are stored on the AP and will thus not trigger another predownload. There is no prior space verification done unfortunately.
If the images will continue to get bigger I think it would be good that Cisco enhances the ap image command set to include such failsafe mechanisms.
@Scott: That path is not present. I only see the individual package files(base, drivers, infra, platform, wcm), where one of them contains the actual AP image. I haven't found a way yet to get a peek into those files.
Patrick
Rasika Nayanajith Tue, 02/04/2014 - 00:56
    2017 Wireless
Hi Patrick,
I have checked my 5760 & can see the those images with its size.
5760-1#dir flash:mnt/images/ap.bak
Directory of flash:mnt/images/ap.bak/
40403  -r--          40   Oct 3 2013 22:29:11 +10:00  ap1g2.md5
40402  -r--    11591680   Oct 3 2013 22:29:11 +10:00  ap1g2
40405  -r--          40   Oct 3 2013 22:29:10 +10:00  ap3g1.md5
40404  -r--    10444800   Oct 3 2013 22:29:12 +10:00  ap3g1
40407  -r--          40   Oct 3 2013 22:29:10 +10:00  ap3g2.md5
40406  -r--    13568000   Oct 3 2013 22:29:11 +10:00  ap3g2
40409  -r--          40   Oct 3 2013 22:29:10 +10:00  c1140.md5
40408  -r--    10291200   Oct 3 2013 22:29:11 +10:00  c1140
40410  -r--          11   Oct 3 2013 22:29:11 +10:00  version.info
3641335808 bytes total (3298693120 bytes free)
You should be able to see it in your one as well. Check it again & see
Rasika
**** Pls rate all useful responses ****
patrick.kofler Tue, 02/04/2014 - 01:10
Hi Rasika,
I checked again. This output represents the flash content of all of our 5760s:
16162  -rwx     2097152  Jan 29 2014 13:59:44 +00:00  nvram_config
16163  -rw-   286925700   Dec 9 2013 09:42:12 +00:00  ct5760-ipservicesk9.SPA.03.03.01.SE.150-1.EZ1.bin
16164  -rw-        1212   Dec 9 2013 12:44:29 +00:00  packages.conf
16166  -rw-    96355812   Dec 9 2013 09:46:08 +00:00  ct5760-base.SPA.03.03.01SE.pkg
16167  -rw-     5616316   Dec 9 2013 09:46:14 +00:00  ct5760-drivers.SPA.03.03.01SE.pkg
16168  -rw-    31611912   Dec 9 2013 09:46:09 +00:00  ct5760-infra.SPA.03.03.01SE.pkg
16170  -rw-    26942336   Dec 9 2013 09:46:10 +00:00  ct5760-platform.SPA.03.03.01SE.pkg
64644  -rw-        2536  Oct 18 2013 14:57:55 +00:00  vlan.dat
24241  drwx        4096   Apr 9 2010 17:47:20 +00:00  guestportal
16169  -rw-    50224444   Dec 9 2013 09:46:11 +00:00  ct5760-iosd-ipservicesk9.SPA.150-1.EZ1.pkg
64646  -rw-   286568868  Apr 10 2010 15:11:59 +00:00  ct5760-ipservicesk9.SPA.03.03.00.SE.150-1.EZ.bin
24249  -rw-    96356448  Apr 16 2010 13:40:28 +00:00  ct5760-base.SPA.03.03.00SE.pkg
24250  -rw-     5616316  Apr 16 2010 13:40:34 +00:00  ct5760-drivers.SPA.03.03.00SE.pkg
24251  -rw-    31634304  Apr 16 2010 13:40:29 +00:00  ct5760-infra.SPA.03.03.00SE.pkg
24252  -rw-    49988784  Apr 16 2010 13:40:32 +00:00  ct5760-iosd-ipservicesk9.SPA.150-1.EZ.pkg
24253  -rw-    26927836  Apr 16 2010 13:40:30 +00:00  ct5760-platform.SPA.03.03.00SE.pkg
24254  -rw-    76040908  Apr 16 2010 13:40:34 +00:00  ct5760-wcm.SPA.10.1.100.0.pkg
16171  -rw-    76170040   Dec 9 2013 09:46:13 +00:00  ct5760-wcm.SPA.10.1.110.0.pkg
There is no mnt directory present.
Patrick
Rasika Nayanajith Tue, 02/04/2014 - 01:31
    2017 Wireless
Hi Patrick,
That's interesting why it is gone missing in your 5760. I have checked this in my 3850s as well  & I can see that mnt folder over there as well. Worth to check this with Cisco TAC as I cannot find any valid reason why it is not there in your case.
3850-2#dir
15490  -rwx     2097152  Jan 16 2014 18:36:49 +11:00  nvram_config
15494  -rw-    79113792  Dec 19 2013 18:33:34 +11:00  cat3k_caa-base.SPA.03.03.01SE.pkg
15495  -rw-     6476476  Dec 19 2013 18:33:34 +11:00  cat3k_caa-drivers.SPA.03.03.01SE.pkg
15496  -rw-    34503664  Dec 19 2013 18:33:34 +11:00  cat3k_caa-infra.SPA.03.03.01SE.pkg
69698  -rw-        1248  Dec 19 2013 18:33:39 +11:00  packages.conf
15498  -rwx         684  Jan 16 2014 18:36:24 +11:00  vlan.dat
15497  -rw-    34788684  Dec 19 2013 18:33:34 +11:00  cat3k_caa-iosd-universalk9.SPA.150-1.EZ1.pkg
69697  drwx        4096  Dec 17 2013 14:39:21 +11:00  mnt
15499  -rw-    25009040  Dec 19 2013 18:33:34 +11:00  cat3k_caa-platform.SPA.03.03.01SE.pkg
15500  -rw-    77296448  Dec 19 2013 18:33:35 +11:00  cat3k_caa-wcm.SPA.10.1.110.0.pkg
5760-1#dir
210082  -rwx     2097152  Dec 20 2013 14:09:57 +11:00  nvram_config
16161  drwx        4096   Oct 8 2013 16:39:24 +11:00  mnt
210090  -rwx         684  Dec 20 2013 11:04:29 +11:00  vlan.dat
193924  -rw-        1212  Dec 19 2013 18:26:41 +11:00  running-packages.conf
48483  -rw-    96355812  Dec 19 2013 18:26:39 +11:00  ct5760-base.SPA.03.03.01SE.pkg
48484  -rw-     5616316  Dec 19 2013 18:26:39 +11:00  ct5760-drivers.SPA.03.03.01SE.pkg
48485  -rw-    31611912  Dec 19 2013 18:26:39 +11:00  ct5760-infra.SPA.03.03.01SE.pkg
48486  -rw-    50224444  Dec 19 2013 18:26:39 +11:00  ct5760-iosd-ipservicesk9.SPA.150-1.EZ1.pkg
161601  -rw-    26942336  Dec 19 2013 18:26:39 +11:00  ct5760-platform.SPA.03.03.01SE.pkg
161602  -rw-    76170040  Dec 19 2013 18:26:39 +11:00  ct5760-wcm.SPA.10.1.110.0.pkg
Rasika
Related Content
