vPC and spanning-tree port type edge
Answered Question
Jan 18th, 2014
I have a 2 N5Ks connected to a pair of UCS FIs. The 5Ks are running vPC to the FI
Correct Answer by Jon Marshall about 3 years 7 months ago
Terry
See the attached for the best practice for vPCs. Taken from the vPC Best Practicies guide (supplied to me by Reza). It is for N7Ks but as far as i am aware the same principles apply.
Jon
Correct Answer by Reza Sharifi about 3 years 7 months ago
spanning-tree port type edge should apply to all access/trunk ports on the FEX.
Basically, any port that connects to end devices should have it.
Overall Rating: 5 (2 ratings)
Reza Sharifi Sat, 01/18/2014 - 19:36
  • Cisco Designated VIP,
    2017 LAN
What is the question?
Terry MacDougal Sat, 01/18/2014 - 19:39
Sorry, it got chopped...... Should the vPCs on the Nexus have "spanning-tree port type edge" enabled?
Correct Answer
Reza Sharifi Sat, 01/18/2014 - 19:43
    2017 LAN
Jon Marshall Sun, 01/19/2014 - 03:10
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Terry
If you mean on the N5Ks then if these are your aggregation layer switches then no, the port type should be normal and it is recommended to enable rootguard on these ports that face the access layer switches.
The uplinks from the FEX should also be normal ports but no rootguard configured.
Jon
Jon Marshall Sun, 01/19/2014 - 06:40
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Terry
They aren't conflicting. Reza was talking about end devices connecting to the FEX  and i was talking about the connections between the FEX and the N5Ks.
Apologies Reza if i have misrepresented what you were saying.
Jon
Correct Answer
Jon Marshall Sun, 01/19/2014 - 06:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Terry
Jon
