Warning message
phones not registering to cucm
Answered Question
Jan 19th, 2014
Hi everyone,
I have one site configured with a dhcp scope on the cucm.
But the phones for that specific site having problems while registering to cucm.
My pub is 10.10.210 and the sub is  10.10.210.11
One phone ( 7960) keeps telling
configuring cm list
cm features disabled
configuring ip
One phone (7961) first it was stuck on the upgrading process.
Then i performed a factory reset that didnt help after i tried ( 3491670 * #)
Now i have a blank screen
I've already placed the firmwares in my Site B router with the firmware files ( term61.default.loads)
All didnt help, so i am totally lost nowe
I'v also attached my running config
Correct Answer by Carlo Poggiarelli about 3 years 6 months ago
Ok.
I'll send you the invitation at 19.00
see you tomorrow
Carlo
Correct Answer by Carlo Poggiarelli about 3 years 7 months ago
Hi.
Yes I meant Voice Vlan at site B.
On Dhcp Scope you have to specify a TFTP server address to let IP phones to know which server they have to contact to download config,firmware and so on.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Overall Rating: 5 (2 ratings)
Carlo Poggiarelli Sun, 01/19/2014 - 14:14
  • Green, 3000 points or more
Hi.
Are ip phones ln Site B receiving ip address?
Did you specify the correct TFTP IP address on DHCP scope?
Is Voice Subnet at Site B able to ping both CUCM?
Let me know.
Regards.
Carlo
monasir81 Mon, 01/20/2014 - 02:32
I can check one of my phones of my SiteB and see that it received a ip adress.
Bute the other  phone i can't check because i did a hard reset and see a blank screen nowe.
I did not specify a tftp adress on dhcp scope ( cucm)
Because i'm using dhcp server with a siteb scope at cucm
Voice subnet ( do you mean voice vlan of siteB router ? )
Correct Answer
Carlo Poggiarelli Mon, 01/20/2014 - 03:50
Hi.
Carlo
monasir81 Mon, 01/20/2014 - 04:29
Hi Carlo,
Thats strange,
I didnt knew that i have to specify tftp adress on dhcp scope.
Because i also have a Site A  ( Site A router connected by trunk to a switch )
These phones dont have tftp adresses specified on the dhcp scope ( for SiteA  CUCM)) but they are registered fine.
Howe can i solve my siteB phone which wont boot up ?
I see a blank screen
Carlo Poggiarelli Mon, 01/20/2014 - 05:20
Hi.
On a phone at site A, check if tftp is defined manully by using alternate TFTP option on the phone.
On site B you can try to create a Dhcp pool on the router as follows:
ip dhcp pool VOICE
network 10.10.201.0 255.255.255.0
default-router 10.10.201.1
option 150 ip 10.10.210.10 10.10.210.11
from router try this
ping 10.10.210.10 source 10.10.201.1 and see if it works.
Carlo
monasir81 Mon, 01/20/2014 - 06:31
Carlo,
Thats a good point what you mentioned.
I can check on both siteA and siteB phones if a tftp adress is defined.
Otherwise i can create a dhcp pool but the problem is i dont want to do this.
Because i want to create a dhcp scope on UCM for SiteB phone.
I'll let you know
monasir81 Mon, 01/20/2014 - 13:31
Hi Carlo i tried the above but i am stil having te same issues.
I've removed dhcp scope ( SiteB)  from cucm.
After that i configured a dhcp pool on SiteB router, excluded adresses
The phone is getting an ip adress of that specific dhcp pool that is not the problem.
But the problem is that the phones cant register to cucm, sometime i see on cucm the phone is registered but if
i look at the phone i can see:
following issues on the phones screen:
cm down features disabled
requesting softkey template
configuring cm list
TFTP retry time out.
SEPXXXX cnf.xml
And the second phone still shows blank screen, factory reset has no effect.
BTW ---->ping 10.10.210.10 source 10.10.201.1 also works fine
monasir81 Mon, 01/20/2014 - 13:33
I forgot to mention:
If i look in my SiteB router i'm several messages:
*Jan 20 22:26:25.189: %DTP-5-NONTRUNKPORTON: Port Fa0/1/3 has become non-trunk
*Jan 20 22:26:25.681: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/3, changed state to down
*Jan 20 22:26:26.689: %LINK-3-UPDOWN: Interface FastEthernet0/1/3, changed state to down
*Jan 20 22:26:28.097: %DTP-5-TRUNKPORTON: Port Fa0/1/3 has become dot1q trunk
*Jan 20 22:26:29.597: %LINK-3-UPDOWN: Interface FastEthernet0/1/3, changed state to up
*Jan 20 22:26:30.597: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/3, changed state to up
*Jan 20 22:28:57.037: %SYS-5-CONFIG_I: Configured from console by vty0 (10.10.111.1)
*Jan 20 22:30:44.073: %DTP-5-NONTRUNKPORTON: Port Fa0/1/3 has become non-trunk
*Jan 20 22:30:44.565: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/3, changed state to down
*Jan 20 22:30:45.573: %LINK-3-UPDOWN: Interface FastEthernet0/1/3, changed state to down
*Jan 20 22:30:46.853: %DTP-5-TRUNKPORTON: Port Fa0/1/3 has become dot1q trunk
*Jan 20 22:30:48.353: %LINK-3-UPDOWN: Interface FastEthernet0/1/3, changed state to up
*Jan 20 22:30:49.353: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/3, changed state to up
*Jan 20 22:33:35.089: %DTP-5-NONTRUNKPORTON: Port Fa0/1/2 has become non-trunk
*Jan 20 22:33:35.581: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/2, changed state to down
*Jan 20 22:33:36.589: %LINK-3-UPDOWN: Interface FastEthernet0/1/2, changed state to down
*Jan 20 22:33:44.877: %DTP-5-TRUNKPORTON: Port Fa0/1/2 has become dot1q trunk
*Jan 20 22:33:46.377: %LINK-3-UPDOWN: Interface FastEthernet0/1/2, changed state to up
*Jan 20 22:33:47.377: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/2, changed state to up
*Jan 20 22:36:03.518: %DTP-5-NONTRUNKPORTON: Port Fa0/1/3 has become non-trunk
*Jan 20 22:36:04.010: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/3, changed state to down
*Jan 20 22:36:05.018: %LINK-3-UPDOWN: Interface FastEthernet0/1/3, changed state to down
Carlo Poggiarelli Mon, 01/20/2014 - 15:23
Hi.
Where is attached the Router At site B .. i mean which kind of switch and how that swtich is configured.
Did you check the routing between sites and verify that the link is stable?
With TFTP retry time out the IP Phone is telling you that it's unable to reach the CUCM.
Please let me know
Carlo
monasir81 Tue, 01/21/2014 - 00:35
Carlo,
I don't use switch for SiteB.
Instead i'm using HWIC-4ESW modules for SiteB router.
These ports ( int fa 0/1/0 - 3) are configured as:
switchport trunk native vlan 201
switchport mode trunk
switchport voice vlan 202
I am able to ping from my SiteB router to PUB/SUB
interface Vlan202
ip address 10.10.201.1 255.255.255.0
ip helper-address 10.10.210.10
Carlo Poggiarelli Tue, 01/21/2014 - 01:09
Hi.
Can you please configure those ports as
switchport mode access
switchport access vlan 201
spanning-tree portfast
Carlo
monasir81 Tue, 01/21/2014 - 03:49
I'll try this tonight and let you know.
p.s before i had my switchports configured as i mentioned earlier, why am i having problems nowe?
monasir81 Tue, 01/21/2014 - 10:58
Hi carlo,
I've applied the changes.
Unfortunately it didnt work.
I have the feeling that the problem is its looking for firmware files?
But i'be already supplied the VG with the firmware files ( 7960 - 7961)
Still no success
Carlo Poggiarelli Tue, 01/21/2014 - 11:07
Hi.
While ip phones will register to CUCM, they will not get firmware from VG.
Can you collect CM trace to verify if ip phones at site B are trying to register to it?
If you want we can setup a webex meeting to verify the issue.
Let me know
Carlo
monasir81 Tue, 01/21/2014 - 12:38
Hi Carlo if thats possible that would be great?
When do you think you can you can do this?
mohamed
Carlo Poggiarelli Tue, 01/21/2014 - 12:43
Hi Mohamed.
In which timezone are you located?
Lef me know so we can adjust a time to setup the conf.
Carlo
Carlo Poggiarelli Tue, 01/21/2014 - 12:51
Perfect!
If is suitable for you, we could start tomorrow at 11.00 AM.
I'll send you the meeting link on your private box
Let me know
Carlo
monasir81 Tue, 01/21/2014 - 12:59
11.00 AM you mean at day ?
That won't be suitable for me then i'm at work
Carlo Poggiarelli Tue, 01/21/2014 - 13:06
Ok. so suggest you a suitable time and I'll let you know my availability
Carlo
monasir81 Tue, 01/21/2014 - 13:12
would 7.30 - 8.00 PM work for you?
I appreciate that your are helping me
Thanks for the support
Correct Answer
Carlo Poggiarelli Tue, 01/21/2014 - 13:15
Ok.
see you tomorrow
Carlo
