Warning message
Video compositor c40
Jan 20th, 2014
My client want unic configoration with his C40 and 2 screens that he have:
A. 1 screen selfview, 2 screen FAR site (this is the default)
B. 1 screen PC presentation, 2 screen PC presentation (presentation through the VC, without confrence)
C. 1. screen - Far site, 2 screen - pc.. (presentation through vc)
can i do it with Video compositor autom automaticly?
Shy
aniefiok essien Mon, 01/20/2014 - 02:24
First thing first check your c40 codec does it have dual display option installed?
Sent from Cisco Technical Support Android App
Shy Solenko Mon, 01/20/2014 - 02:41
Yes offcourse the c40 is dual display!!!
Kenneth Hicks IV Mon, 01/20/2014 - 04:23
  • Cisco Employee,
Shy,
  unless either of those layouts are already built in to the Video compositor for TC console, you will not be able to use this configuration on your C40.  C40's allow the customization of default layouts and which are visible to choose from, but do not allow the customization of layouts.  Only the C60 and C90 support this capability (creating custom layouts).
Kenny
Shy Solenko Mon, 01/20/2014 - 04:28
Thanks for your reply
I will see if it's available in the TC console
Shy Solenko Mon, 01/20/2014 - 04:35
do you know maybe if such configuration is available in the TC console?
Kenneth Hicks IV Mon, 01/20/2014 - 04:44
  • Cisco Employee,
Shy,
  Yes, the video compositor in TC console allows you to create custom layouts but only for the C60 and C90 codecs.  On the C40 we are only able to customize the order of the default layouts and edit which are availalbe for use.  You will not have the option to edit layout familieson the C40 to create custom layouts thought.
Kenny
Related Content
