Warning message
Call handler routing question
Answered Question
Jan 20th, 2014
Can  a caller handler route  to an extension based on a time of day?      For example, incoming call during business hours, caller presses 0  and the call goes to the operator.    Incoming calls during closed hours, caller presses 0 and the call goes to the watchman.      Is this possible?
Thanks-    Pat
Correct Answer by kelvin.blair about 3 years 7 months ago
If you are using Cisco Unity Connection, then you can use the system schedules to accomplish your question.  Basically, you will tell option 0 to send to a call handler "Called Operator" or whatever.  you will tie a schedule to this and use the transfer rules Closed & STandard.  During Standard Hours (Business Hours) transfer to X and During Closed Transfer to X.  Another way is to route the call back to CUCM and use ToD routing in CUCM.  The easiest is to use Unity.
Overall Rating: 5 (1 ratings)
Correct Answer
kelvin.blair Mon, 01/20/2014 - 08:27
  • Silver, 250 points or more
pluedke1107 Mon, 01/20/2014 - 08:38
Wow!  That was incredibly easy.    Thank you Kevin.
Related Content
