DHCP Snooping not enabled for all Vlan.
Jan 20th, 2014
We have enabled dhcp snooping for all vlan configured on the switch, but only few vlan show up as operational. Please clarify.
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(53)SG8, RELEASE
ip dhcp snooping vlan 30,100-119,300-349,400-449,600,700,710,996-997
Switch#sh ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
DHCP snooping is operational on following VLANs:
30,108,308,600,700,710,996-997
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is disabled
   circuit-id default format: vlan-mod-port
   remote-id: 0026.9914.8a80 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface                  Trusted    Allow option    Rate limit (pps)
TenGigabitEthernet5/1      yes        yes             unlimited
  Custom circuit-ids:
TenGigabitEthernet5/2      yes        yes             unlimited
  Custom circuit-ids:
Port-channel1              yes        yes             unlimited
  Custom circuit-ids:
Jeff Van Houten Mon, 01/20/2014 - 21:08
  • Silver, 250 points or more
Is there an active port on that switch for the non-operational snooping Vlans?
devils_advocate Tue, 01/21/2014 - 06:56
  • Gold, 750 points or more
  • Community Spotlight Award,
    Small Business, November 2015
Initially I thought the same as Jeff in that you needed ports in the Vlans before they became operational for DHCP snooping but a quick test on a 3750x I have here disproved that.
The only way I could replicate your scenario was to enable DHCP snooping for non existant Vlans.
For example, enabling DHCP snooping for Vlans 10-20 would show:
10-20
10-20
But ONLY if Vlans 10-20 existed as L2 vlans.
If I deleted Vlan 19, I see the following:
10-20
10-18,20
I suspect you have enabled DHCP snooping for L2 Vlans which do not actually exist in the Vlan database on that switch??
