How to load configuration using Cisco USB port???
Answered Question
Jan 20th, 2014
  • Почетные Знаки Сообщества,
    Новичок, Январь 2014
on USB-flush configuration there. I try to download it gives this:
Switch#copy usbflash0: 3560-ST
Source filename [3560-st]?
Destination filename [3560-ST]?
%Error opening usbflash0:3560-st (File not found)
What is the Problem? flash formatted on most Cisco (it has decreased in numbers from 16 GB to 2.75 GB)???
Correct Answer by Collin Clark about 3 years 6 months ago
If you are copying the config from USB to the running config-
copy usbflash0:conf-file-name running-config
If you want to copy the running config to USB-
copy running-config usbflash0:
Overall Rating: 5 (1 ratings)
chandra_rc16 Mon, 01/20/2014 - 22:28
Hope this helps.
copy usbflash0:filename.txt
Chandu
Amit Singh Tue, 01/21/2014 - 03:25
  • Cisco Employee,
Syntax is the one as Chandu poined out.
However, i see there is a space between usb0: and the filename.
"Switch#copy usbflash0: 3560-ST"
Make sure there is no space in the syntax above and also the file name is correct.
Egor Khomenko Tue, 01/21/2014 - 19:25
Thank you so much. It would seem a trifle. But, I had a little brain naprech. It is a trifle, which I came twice
Correct Answer
Collin Clark Tue, 01/21/2014 - 10:56
  • Purple, 4500 points or more
pieterh Tue, 01/21/2014 - 12:39
Depending on the model, the internal flash may allready be refernced with usbflash0
If so the external USB may be usbflash1
