Warning message
Walter Dey Wed, 01/22/2014 - 03:33
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Unified Computing, Storage Networking
Although technically it will work, it is most likely not supported/tested, not even recommended
t-asteris Wed, 01/22/2014 - 06:06
Hi wdey,
But the hardware compatibility matrix includes a number of FC Tape libraries. So my guess is at least the devices which are included in the compatibility matrix should be able to be connected directly to the FI.
Walter Dey Wed, 01/22/2014 - 06:22
http://www.cisco.com/en/US/docs/unified_computing/ucs/interoperability/matrix/r_hcl_B_rel2.21.pdf
Enterprise Backup Interoperability Matrix
Table 8 lists the tape library models that are supported with this version of the Unified Computing System.
Note
Direct connect of tape libraries is not supported.
