Warning message
SNTP-3-FATAL_ERROR_OCCURED
Jan 21st, 2014
I'm not sure when it started, possibly when i upgraded to the 7.5 wlc code but on my 5508 my message log is getting spammed with
*sntpReceiveTask: Jan 21 09:57:06.309: #SNTP-3-FATAL_ERROR_OCCURED: sntp_main.c:233 Fatal error: : socket index (2) out of range or not open (socket.c:403).
*sntpReceiveTask: Jan 21 09:57:06.309: #SNTP-3-FATAL_ERROR_OCCURED: sntp_main.c:233 Fatal error: : unable to send NTP packet to %s ::ffff:69.167.160.102.
the ip 69.167.160.102 was the 3rd ntp server listed under controller -> ntp so for a test i deleted it. But now it's spamming the same message about the 2nd server in my list.
There doesn't seem to be much to the ntp config so I'm not sure where to go to stop this
Thanks for any help
Overall Rating: 5 (5 ratings)
Scott Fella Tue, 01/21/2014 - 07:31
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I have not seen that and I have clients with multiple NTP servers listed.  What code did you upgrade from?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
rraineri Wed, 03/12/2014 - 17:19
Hi Guys,
I have the same issue with a 5508 and a syslog server showing the following message:
"DW2WLC01.SYS: *sntpReceiveTask: #SNTP-3-FATAL_ERROR_OCCURED: sntp_main.c:233 Fatal error: : unable to send NTP packet to ::ffff:172.23.254.89."
IPv6 is already disabled.
Any other possible suggestion?
Thank you.
richard bedwell Mon, 10/13/2014 - 13:04
I have been studying for my CCNA Wireless, and just today configured my WLC 2504 to use my syslog server. I have seen the cascading errors you are talking about. In about 5 min, I had 75 pages of logs....
What I did to stop this, believe it or not, after trying the disabling of IPv6 which didn't help, I simply deleted all my defined NTP servers, and recreated one. This stopped the logs for now.
stephendrkw Mon, 10/13/2014 - 23:23
Hi Richard, this must of been a bug. When I upgraded my 5508's, these messages never appeared again.
best regards,
richard bedwell Mon, 10/13/2014 - 23:39
It is my belief this is still an issue, my wlc was bought NIB, and has the latest 7.6 image on it... I checked Cisco bug tool and found nothing for this, anyway fixed it on my wlc, hopefully this will help some else that is having the same issue.
stephendrkw Wed, 04/09/2014 - 00:24
...tpReceiveTask: Apr 09 08:19:49.523: #SNTP-3-FATAL_ERROR_OCCURED: sntp_main.c:233 Fatal error: : unable to send NTP packet to %s ::ffff:10.171.64.254.
My code version is 7.5.102.0 (5508)
Rasika Nayanajith Tue, 01/21/2014 - 09:54
  • Purple, 4500 points or more
    2017 Wireless
It's looks like WLC trying to send NTP packets to IPv6 address & that fails.  If you are not using IPv6 then disable it globally on your WLC & see if that helps
(WLC) >config ipv6 disable
(WLC) >show ipv6 summary
Global Config............................... Disabled
Reachable-lifetime value.................... 300
Stale-lifetime value........................ 86400
Down-lifetime value......................... 30
RA Throttling............................... Disabled
RA Throttling allow at-least................ 1
RA Throttling allow at-most................. 1
RA Throttling max-through................... 10
RA Throttling throttle-period............... 600
RA Throttling interval-option............... passthrough
NS Multicast CacheMiss Forwarding........... Disabled
NA Multicast Forwarding..................... Enabled
Rasika
*** Pls rate all useful responses ****
melissa mehlenbacher Wed, 02/04/2015 - 08:01
I had the same error.  Seems to be resolved now that I removed an invalid NTP server from the configuration.
jinglei yan Mon, 10/26/2015 - 06:44
I have the same error. Do you have resolve the issue? Can you give me some suggestion?
Related Content
