Warning message
DNS Resolution in Cisco ASA 5525
Jan 21st, 2014
Hey all,
I will begin by telling you what my end goal is, I am trying to block specific websites on our cisco ASA 5525 using FDQN. I know that this functionality for DNS resolution was not implemented until a specific version.
Current Version: Cisco ASA 5525
ASA Version: 8.6(1)
I can ping external addresses from the ASA however I cannot ping hostnames like "ping google.ca" does not work.
What I've done.
dns domain-lookup inside
dns domain-lookup outside
name-server x.x.x.x (Primary internal dns server)
name-server x.x.x.x (Secondary internal dns server)
name-server 8.8.8.8 (Google external dns server)
name-server 8.8.4.4 (Google external dns server)
domain-name example.com
With this config I can, however, ping hostnames of internal servers.
This is an example of me pinging an external hostname.
ciscoasa# ping google.ca
Sending 5, 100-byte ICMP Echos to 2607:f8b0:4009:803::101f, timeout is 2 seconds:
No route to host 2607:f8b0:4009:803::101f
Success rate is 0 percent (0/1)
Any ideas?
Thanks!
johnlloyd_13 Wed, 01/22/2014 - 00:20
  • Blue, 1500 points or more
hi jonathan,
could you try adding using the default DNS group?
dns server-group DefaultDNS
name-server x.x.x.x
name-server 8.8.8.8
name-server 8.8.4.4
Cityofrefuge7 Wed, 01/22/2014 - 05:53
Hi John,
Thanks for your quick reply.
I forgot to mention that I was adding the name servers and domain name to the DefaultDNS group already, though I did remove my secondary internal dns server to reflect exactly what you sent to me, unfortunately still no luck.
johnlloyd_13 Wed, 01/22/2014 - 06:43
Could you post 'ping www.google.com' and 'show route' output?
Cityofrefuge7 Wed, 01/22/2014 - 12:29
officeasa# ping www.google.com
Sending 5, 100-byte ICMP Echos to 2607:f8b0:4009:802::1012, timeout is 2 seconds:
No route to host 2607:f8b0:4009:802::1012
John, due to the sensitive nature displayed within show route output, is there any other information I can tell you, what exactly did you need to see from this information?
(I know without certain information you cannot help but I need to ensure security on my end)
Thanks for understanding.
