01-22-2014 12:09 PM - edited 03-17-2019 03:53 PM
Good afternoon ,
I'm currently installing a demo of cwms in a customer. I 'm installing a small system with 50 users IRP . I make the deployment of the two virtual machines on a C220 M3 server, the memory requirements and recommended space, CPU are meets.
after the deployment of virtual machines, I turn ON the 2 machines , I suggest the link to continue the deployment , I connect and introduce the requested data: private VIP, Public VIP, and URL of meetings and administration . this happens after checking the data and introduce the IRP system machine is the machine and asked me to continue .
when I press the button to continue , turn to the verification system and stays there . 5 minutes throws an error message in the status of the implementation and the page gets stuck , all buttons are disabled , will not let me move forward or backward to correct the error .
I delete the virtual machines and create new ones and still throwing me the error.
any help or advice with this fault ?
Can I restart the process of first deployment, when this happend i don´t know how to recover the process.
the version is: 1.5.1.6.A
thanks in advance .
01-22-2014 09:09 PM
Are you doing auto deployment using vcenter?
Have you checked your network connectivity, DNS etc. as the system will verify everything before completing the installation.
Looks like its not giving any error number like 3XX or did it ever?
-Terry
01-23-2014 03:56 PM
No the deployment is manual and the screen don't show any message.
Just stuck.
Any advice?
Sent from Cisco Technical Support Android App
02-03-2014 10:14 AM
Any news for this post ?
I have currently the same issue....
02-03-2014 11:25 AM
Were these deployments done using vCenter or were they done directly using vSphere connected to the ESXi host for the CWMS VM?
Does the checksum and size of the OVA used for the deployment match the information provided in the eDelivery download or USB physical delivery?
Derek Johnson
Conferencing TAC
02-03-2014 12:13 PM
Hi.
I perform de deploy using ESXi and Vcenter.
The checksum of the OVA was check this file was provide for my AM....
Actually my AM support me and open a ticket in TAC...
The support engineer is working...
Regards.
02-04-2014 01:20 AM
Hi sjvitales,
Please double check the firewall port configuration between the IRP servers & Admin servers.
This solved the same issue in my environment.
Michaël
02-05-2014 08:31 AM
I found I had to ssh the ova file to the datastore on the ESX host. Installing from VCenter gives you the option to look in the datastore for ova files.
