Warning message
Pix 525 through put question
Jan 22nd, 2014
We're having an issue with out Pix 525 cluster, what we're seeing is the following:
* using iternet speed tests while going through the Pix we have trouble getting past 40Mbps of our 100Mbps pipe.
* When I place the laptop outside the Pix we get 90+ Mbps. This is still going through the same internet switch and router.
* Pix CPU, Memory etc in the ADSM dashboard don't show anything that would explain this.
* switch ports that the Pix connects into seem fine, no errors.
I will be going through them again, but if they are fine I'm wondering what I can look at next. Is there a command that might show if the Pix is being taxed?
thanks
John
prateeve Thu, 01/23/2014 - 10:05
Hi John,
Try to connect laptop directly to Pix interface and then check what exactly the speed you are getting, by that I mean just bypass the switch.
- Prateek Verma
