Warning message
License inquiry in the MSE8000
Answered Question
Jan 22nd, 2014
Dear all,
Based on Port matrix table of the  Administrator Guide
Mode          Licenses per port     Video ports
SD                          1                          80
HD                          2                          20
HD+                       4                           20
Full HD                   4                          15
Since our client would like to depoly "Full HD" in their network, anyone can confirm the maximum participant ( we guess is 15).
We did not need to buy full license on this case, the number of license(L-8420-2PL) should be 30  for this case?
Best Regards,
Ben Lai
Correct Answer by Martin Koch about 3 years 6 months ago
Yes, the numbers look ok, at least for a single 8510 blade.
The backdraw is that even if you would dial in with a low resolution device
it will still take one full hd port.
I would recomend you to look into the conductor and the telepresence server.
(Contact your Cisco Partner or Representative regards converting a 8510 to
a telepresence blade and condidtions for the Conductor).
That combination would give you a dynamic port allocation method, so depending
on the scenario you could get more users on it.
(from the TPS release notes:)
Please remember to rate helpful responses and identify helpful or correct answers.
Overall Rating: 5 (1 ratings)
Correct Answer
Martin Koch Thu, 01/23/2014 - 04:03
  • Red, 2250 points or more
LAI CHEUK BUN Mon, 01/27/2014 - 18:18
Dear Martin,
Thanks for your advise.
It is right there is a backdraw for such deployment.
We have a quick review on the dynamic port allocation, it seem much more efficient in MCU resource arrangement.
Best Regards,
Ben
