01-22-2014 10:22 PM - edited 03-07-2019 05:44 PM
Hi Experts,
We are getting UNKNOWN source when login failed, what is the issue why it is not showing source IP Address.
000465: .Jan 22 20:52:00.889 UTC: %SEC_LOGIN-4-LOGIN_FAILED: Login failed [user: XXXXXX ] [Source: UNKNOWN] [localport: 23] [Reason: Login Authentication Failed - BadPassword] at 20:52:00 UTC Wed Jan 22 2014
Current IOS: c7200p-adventerprisek9-mz.152-4.S4.bin
Please suggest me how to fix it to get source IP Address.
Thanks in ADV,
01-23-2014 09:26 PM
Dear Experts,
Please anyone help me to fix it.
10-09-2015 02:19 AM
dc-csa-bir
Could you able to fix this problem ?
if yes please tell me
03-04-2016 02:15 AM
I am also getting the same problem with failed login attempts and unknnown source :
%SEC_LOGIN-4-LOGIN_FAILED: Login failed [user: unknown] [Source: UNKNOWN] [localport: 23] [Reason: Login Authentication Failed] at 14:33:00 Fri Mar 4 2016
if you got any solution please inform .
03-10-2015 06:04 PM
I have a bunch of different router models and it appears that this trouble is only with those running 15.1-(4M9 in my case). The ones running 12.4 or 15.4 are ok, so at this point I'm assuming than with your 15.2 near my 15.1, it sounds like a bug in the IOS and we are the only guys on Google having this trouble. I can't upgrade routers running 15.1 to something better because they are all EOL products and this is the last version released for all of them.
If I found something else one day, I'll be back to drop a note.
