Warning message
Root and Intermediate Certifcate
Jan 23rd, 2014
I have a probleme with installing a Certificate into the ASA. I have followed the following link http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808b3cff.shtml but I keep getting a error bij installing the certificate that I received from my 3rd Party CA Vendor.
I have followed the instructions 5 times and I still get the error ERROR: Failed to parse or verify imported certificate or Certificate does not contain general purpose public key. I think that reason why I am getting this error is because of my certificate needs a root and intermerdiate certificate.
The certificate I want to install is Comodo PositiveSSL. So can anyone help me how I can solve this problem?
Marcin Latosiewicz Fri, 01/24/2014 - 07:55
  • Cisco Employee,
Check if you can decode it with SSL before you jump to conclusions.
Are you installing identity or SA/subCA certs? Is the cert based on a CSR or pre-genrated by CA?
martijngroenen Fri, 01/24/2014 - 14:41
I have checked the certiticate on my computer after I installed the root and intermediate certificate and certificate looks perfect.
I get tehe errors after I installed the root or intermediate certificate. So the questionnis how can I install a root and intermediate ceritficate.
The certificate is based on CSR.
