Warning message
Peralta Imee Ma... Mon, 01/27/2014 - 08:27
  • Cisco Employee,
Hi Aleksandr,
Good Day!
Please be informed that we don't have the provision to move items inside the configuration and it will be possible only through quote.
You can arrange the sequence of your configuration under the quote by going to QUOTE TAB >> DISCOUNTS & CREDITS >> FORMAT QUOTE >> then drag the line items and arrange it according to your sequence preference.
If you wish to request for this feature, please send email to [email protected]
as an enhancement issue. However, you will need to fill out a template first and then send it to that alias.
To get the template, we suggest that you create a case with us online at http://www.cisco.com/cisco/psn/web/workspace or by calling 1-800-553-6387 options 2 and 3.
If this is your first time to open a case using Customer Service Central, you will need to sign in to your My Cisco Workspace (http://www.cisco.com/cisco/psn/web/workspace)     and then add the Customer Service Central module to your Workspace  to    open and manage your cases online. Help and support documentation  is    available on Operations Exchange.
Imee P.
CCW Support
