Warning message
[RV220W] WI-FI CONNECTION AT 300 mbps
Jan 25th, 2014
Hello guys,
are any of you can connect via wifi to the router Cisco RV220W to 300mbps? With what configuration (auto-mode or manual)? I am unable to connect at 150 mbps sometimes but no more. thanks
Daniele
Daniele Fulgenzi Mon, 01/27/2014 - 03:16
Hi Marc,
the wifi from my pc does not see the network at 5 GHz. Your speed wifi is 300 mbps?
msavard99 Mon, 01/27/2014 - 03:27
Hi Daniele,
Im currently using a new router but I still have the RV220w and Ill try it this morning and will report back in a few hours max.
Marc
msavard99 Mon, 01/27/2014 - 03:54
I get 300 Mbps with these settings (I can try later @ 2.4GHz if you want):
http://i39.tinypic.com/2s6vg41.jpg
msavard99 Mon, 01/27/2014 - 06:31
I also get 300Mbps @ 2.4GHz.
All at default settings so your "problem" is probably with your NIC, how old is it ?
Those 2 tests were made using the built-in Atheros in an HP computer and I also get excellent connection with a TPLINK/USB 2.0. I only get 150 Mbps with this one but that computer is far from the router.
Settings:
http://i40.tinypic.com/o8h30l.jpg
Daniele Fulgenzi Mon, 01/27/2014 - 06:42
Thank you very much. I think the problem are my wireless hardware .
My laptop wifi connection is Atheros AR9485WB-EG and max speed is 150 mbps at 2,4 Ghz.
