Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929650members
1244439discussions
Community Activity
CBS350-8XT too noisy
I own a CBS350-8XT that is far too noisy. I even purchased a sound meter to obtain a measure and it goes up to 70db where the maximum indicated in the user manual is 41.3db. I would like to open a ticket or something for cisco to fix my unit. How sha...
How do I get a refund from Aeromexico? Quick~Guide
How Can I Speak to a Aeromexico 픸핚핣핝핚핟핖핤 Representative Fast?  【Aeromexico Guide 헙헮혀혁 & 헙혂헿헶헼혂혀】 Talk to someone on Aeromexico 픸핚핣핝핚핟핖 smoothly, give their dedicated support line a ring at + ퟭ-877 ✈ 559 ✈ 0161 . Take your time and listen carefully t...
ice771 by Level 1
  • 2 Views
  • 0 replies
Can I cancel my Aeromexico 𝗙light and get a refund? Contact US
ice771 by Level 1
  • 2 Views
  • 0 replies
AnyConnect DNS Issue
We are having an issue were after disconnecting from AnyConnect and connecting the next day, they get a new IP in AnyConnect but in our local DNS they have another IP which I assume is probably from the day before. This obviously causing name resolut...
jf1134 by Level 1
  • 45 Views
  • 4 replies
{AMX} 100% Aeromexico 𝗙light and request a refund? Need Assistance
ice771 by Level 1
  • 1 Views
  • 0 replies
What is Aeromexico 24 hour policy? Aeromexico Guide
ice771 by Level 1
  • 2 Views
  • 0 replies
VPN Tunnel connecting at a unconfigured setting - Phase 1 Timer
OK, so I've got a set of ASA's and we are migrating them to Firepowers, and all seems ok. In the past we have noticed that for some reason on the ASA's, no matter what you specify as the parameters for phase 1, the rekey timer always connects at 3600...
Screenshot 2024-04-25 142720.png Screenshot 2024-04-25 142752.png StephenCarter_0-1714052852588.png
Cisco WLC upgrade
Hello!  I have configured WLC with software version 8.8.130.0.  To which version is it recommended to upgrade? Thank you!
How do I get a refund from Aeromexico? 【✈️ Contact Now
ice771 by Level 1
  • 2 Views
  • 0 replies
FTD re-register to FMC chassis mode
Deployed a 3100 in chassis mode to the FMC a few days ago. All went to plan.Determined we needed to change the IP so decided just to delete the device from FMC and re-provision it.On the FTD via local-mgmt did a erase configuration. The device wiped ...
glsparks by Level 1
  • 53 Views
  • 3 replies
DNAC Backup failure
Hello  I have the below issue when trying to backup on DNAC, please assist BACKUP.PREPARE_BACKUP FAILURE DataValidationError BACKUP.maglev-system:credentialmanager FAILURE BACKUP.fusion:postgres FAILURE BACKUP.maglev-system:glusterfs-server FAILURE B...
Cisco 2960S not pinging, but has DHCP address
Hi,I am trying to set up an SSH connection to my switch, but right now there is some lower level problem. I have set up my FastEthernet0 interface to ip address dhcp and the command show interfaces FastEthernet0 shows the correct address. Even if I t...
limex by Level 1
  • 59 Views
  • 3 replies
ATA 192 not registering with Webex Calling
I have an ATA192-3PW-K9 V04 and cannot get it to register. I have it flashed to the latest firmware. I created the device as a workspace with it's mac address and DID/extension in Webex. When I factory reset the device, all I'm doing is going to voic...
