Warning message
Обновил ИОС на сиско 3560 с версии 12,2 до 15,2. и выдается такая ошибка НТП
Jan 26th, 2014
  • Почетные Знаки Сообщества,
    Новичок, Январь 2014
Jan 27 09:10:01 XXX: NTP Core (NOTICE): Clock synchronization lost.
.Jan 27 09:10:02 XXX: NTP Core (INFO): x.x.x.x 8014 84 reachable
.Jan 27 09:10:04 XXX: NTP Core (INFO): x.x.x.x 962A 8A sys_peer
.Jan 27 09:10:04.644: %SYS-6-CLOCKUPDATE: System clock has been updated from 09:10:04 XXX Mon Jan 27 2014 to 09:10:04 XXX Mon Jan 27 2014, configured from NTP by x.x.x.x
.Jan 27 09:10:04 XXX: NTP Core (NOTICE): time reset 0.000000 s
.Jan 27 09:10:04 XXX: NTP Core (NOTICE): trans state : 5
.Jan 27 09:10:05 XXX: NTP Core (INFO): x.x.x.x 8034 84 reachable
.Jan 27 09:10:07 XXX: NTP Core (INFO): x.x.x.x 964A 8A sys_peer
.Jan 27 09:10:07 XXX: NTP Core (NOTICE): frequency error 0. PPM exceeds tolerance 0. PPM
.Jan 27 09:10:07 XXX: NTP Core (NOTICE): Clock is synchronized.
Jan 27 09:10:09.492: %SYS-5-CONFIG_I: Configured from console by Xxxx on vty0 (x.x.x.1)
Jan 27 09:11:13 XXX: NTP Core (NOTICE): frequency error -0. PPM exceeds tolerance 0. PPM
Jan 27 09:13:05 XXX: NTP Core (NOTICE): Clock synchronization lost.
.Jan 27 09:13:05.000: %SYS-6-CLOCKUPDATE: System clock has been updated from 09:13:01 XXX Mon Jan 27 2014 to 09:13:05 XXX Mon Jan 27 2014, configured from console by xxxxxx on vty0 (x.x.x.1).
.Jan 27 09:13:05 XXX: NTP Core (INFO): x.x.x.x 8054 84 reachable
.Jan 27 09:13:57 XXX: NTP Core (INFO): x.x.x.x 966A 8A sys_peer
.Jan 27 09:13:57 XXX: NTP Core (NOTICE): Spike event  s
.Jan 27 09:14:58.627: %SYS-6-CLOCKUPDATE: System clock has been updated from 09:15:02 XXX Mon Jan 27 2014 to 09:14:58 XX Mon Jan 27 2014, configured from NTP by x.x.x.x
.Jan 27 09:14:58 XXX: NTP Core (NOTICE): time reset nan s
.Jan 27 09:14:58 XXX: NTP Core (NOTICE): trans state : 5
.Jan 27 09:14:59 XXX: NTP Core (INFO): x.x.x.x 8074 84 reachable
What is the Problem?
Haihua Rong Wed, 01/29/2014 - 17:45
  • Bronze, 100 points or more
Алло Andrey,
Я хотел бы подтвердить, если есть только один главный NTP.
Если нет проблема там, то, пожалуйста, попробуйте перенастроить NTP, вход:
нет NTP-сервер
нет NTP-сервер (2 раза Пожалуйста, не потому что иногда маршрутизаторы
удалить его с первой попытки)
NTP и настроить снова.
Пожалуйста, дайте мне знать, как это идет, также, чтобы лучше понять вашу проблему, пожалуйста, пришлите мне
Из следующей отладки копии с момента синхронизации теряется
debug ntp packet
Haihua
