Warning message
Problems with 7940/7941 phones
Answered Question
Jan 26th, 2014
I am new to the Cisco Call Manager and IP Telephony. I am also volunteering for a non-profit museum that had a 1760 with several 7940/7941 phones donated. All but three of the phones display correct time zone settings. The three phones (two 7940 and one 7941) have a file not found error when booting. The profile file they are looking for is in the flash of the 1760. All phones are on the correct VLAN and are pulling correct IP information.
A side note is that due to the load on the 1760, we can not access the GUI of the 1760. One option there is to remove the LAN segment, login to the GUI and make any changes needed. One of my options that I have not tried yet. Is replacing one of the problem phones with a "spare" and updating the MAC for the user.
The phones are reporting "File not found: P00308000500"
Here is the show version and show flash from the 1760 for reference.
cme1760#sh ver
Cisco IOS Software, C1700 Software (C1700-ADVENTERPRISEK9-M), Version 12.4(15)T, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 25-Jun-07 18:39 by prod_rel_team
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
cme1760 uptime is 3 days, 10 hours, 50 minutes
System returned to ROM by error - a Software forced crash, PC 0x80712D68 at 08:29:54 pst Thu Jan 23 2014
System restarted at 08:34:37 pst Thu Jan 23 2014
System image file is "flash:c1700-adventerprisek9-mz.124-15.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 1760 (MPC860P) processor (revision 0x500) with 123566K/7506K bytes of memory.
Processor board ID FOC07380X5Y (3012668611), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 FastEthernet interface
32K bytes of NVRAM.
65536K bytes of processor board System flash (Read/Write)
cme1760#sh flash
System flash directory:
File  Length   Name/status
  1   26479732  c1700-adventerprisek9-mz.124-15.T.bin
  2   4802     admin_user.html
  3   672015   admin_user.js
  4   16040    Chime.raw
  6   8160     Classic1.raw
  7   716      CME_GUI_README.TXT
  8   1045952  cmterm_7920.4.0-02-00.bin
  9   331483   CP7902080001SCCP051117A.sbin
10   338840   CP7905080001SCCP051117A.sbin
11   338424   CP7905080001SCCP051117A.zup
12   340631   CP7912080001SCCP051117A.sbin
14   2823     DistinctiveRingList.xml
15   16344    dom.js
17   6146     ephone_admin.html
19   3724     normal_user.html
20   81443    normal_user.js
21   349794   P00405000700.bin
22   350198   P00405000700.sbn
23   1908762  P00503010100.bin
24   8160     Piano1.raw
26   7200     Pulse1.raw
27   2624     Readme7960-40.txt
28   4000     Ring1.raw
29   4000     Ring2.raw
30   4000     Ring3.raw
31   495      RingList.xml
32   49169    S00104000100.sbn
33   49599    S00105000200.sbn
34   10800    Sax1.raw
37   2431     telephony_service.html
39   9968     xml-test.html
40   3412     xml.template
41   5821     eps1 [deleted]
42   5596     bv.ted [deleted]
43   5907     bv.ted [deleted]
44   6099     bv.ted [deleted]
45   6178     bv.ted [deleted]
46   129832   P00308000500.bin
47   130236   P00308000500.sbn
48   752516   P0S308000500.sb2 [deleted]
49   461      P0S300805000.loads [deleted]
50   290819   crashinfo_20140123-162954
[33799908 bytes used, 33308952 available, 67108860 total]
Thank you in advance for any assistance.
Correct Answer by Manish Prasad about 3 years 6 months ago
Hi Troy,
Check phone type mentioned under ephone of these three phones . Like this..
ephone  1
type 7940
If its there can you attach "debug tftp events" and "sh telephony-service tftp-bindings" , when one of the faulty phone try to register with CME.
Rate all the helpful post.
Manish
Overall Rating: 5 (1 ratings)
Correct Answer
Manish Prasad Thu, 01/30/2014 - 02:13
Hi Troy,
ephone  1
type 7940
Manish
Troy Vail Sat, 02/08/2014 - 23:35
Manish,
Thank you for your reply. I found the type for each of the phones with problems was set incorrectly. Some phones had:
ephone 1
type 7960 or type 7920
The tftp debug showed that a 7941 that had a type of 7960 trying to load the profile for 7960. Once the type was set correctly, the phone loaded correct profile and the time zone displayed correctly.
Thank you again.
Troy
Now for me to find a replacement for the 1760 for a resonable price.
