Warning message
cisco switch WS-C3750X-48T cpu utilization issue
Jan 26th, 2014
Hi All,
I have a swich WS-C3750X-48T and i am facing the issue of high cpu utilization .
Please suggest the reason why the switch is behaving like this and what is the solution of that.
please find the log....
UG-GW-CORE#sh proc cpu | e 0.00
CPU utilization for five seconds: 34%/1%; one minute: 36%; five minutes: 36%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  10      833688   1686490        494  0.31%  0.71%  0.63%   0 ARP Input
  69      144766     30391       4763  0.15%  0.13%  0.11%   0 Compute load avg
  74     4470389    735065       6081  2.86%  2.75%  2.77%   0 RedEarth Tx Mana
  80     1068811     60462      17677  0.79%  0.70%  0.65%   0 Adjust Regions
116     2567337    295705       8682  1.58%  1.55%  1.56%   0 hpm counter proc
156    24497604   2908539       8422 15.57% 14.80% 14.65%   0 Hulc LED Process
167      546741     30415      17976  0.31%  0.31%  0.31%   0 HQM Stack Proces
198      604538   1052522        574  0.31%  0.58%  0.55%   0 IP Input
217     8967911   1674951       5354  6.04%  5.16%  5.23%   0 Spanning Tree
glen.grant Mon, 01/27/2014 - 06:16
  • Purple, 4500 points or more
  That's not exceptionally high ,  typically thw hulc led process tends to be a code issue so you might want to look at a different version or use the bug tool to see if your version has that issue.
Madhuraj singh ... Mon, 01/27/2014 - 22:44
Thanks for the reply ...
Actually I replace the old switch with this one .
The olod switch was having only 20 % of cpu utilization .
but from when I replaced the old switch with the same model 3750 the cpu utilization become 45% with the same configuration of network.
some other logs is ...
UG-GW-CORE#sh ip route summary
IP routing table name is Default-IP-Routing-Table(0)
IP routing table maximum-paths is 32
Route Source    Networks    Subnets     Overhead    Memory (bytes)
connected       0           25          1600        3800
static          7           33          2560        6080
eigrp 111       2           70          9216        10944
internal        6                                   7032
Total           15          128         13376       27856
UG-GW-CORE#sh ip traffic
IP statistics:
  Rcvd:  1278413 total, 1231221 local destination
         0 format errors, 0 checksum errors, 37722 bad hop count
         0 unknown protocol, 6495 not a gateway
         0 security failures, 0 bad options, 271 with options
  Opts:  0 end, 0 nop, 0 basic security, 0 loose source route
         0 timestamp, 0 extended security, 0 record route
         0 stream ID, 0 strict source route, 271 alert, 0 cipso, 0 ump
         0 other
  Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
         0 fragmented, 0 couldn't fragment
  Bcast: 517037 received, 3132 sent
  Mcast: 70972 received, 875079 sent
  Sent:  1617393 generated, 504595072 forwarded
  Drop:  861551 encapsulation failed, 0 unresolved, 0 no adjacency
         4 no route, 0 unicast RPF, 0 forced drop
         0 options denied, 0 source IP address zero
ICMP statistics:
  Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 18 unreachable
        164547 echo, 45 echo reply, 0 mask requests, 0 mask replies, 0 quench
        0 parameter, 0 timestamp, 0 info request, 0 other
        0 irdp solicitations, 0 irdp advertisements
  Sent: 0 redirects, 1026 unreachable, 50 echo, 164547 echo reply
        0 mask requests, 0 mask replies, 0 quench, 0 timestamp
        0 info reply, 6 time exceeded, 0 parameter problem
TCP statistics:
  Rcvd: 425143 total, 0 checksum errors, 1 no port
  Sent: 517028 total
EIGRP-IPv4 statistics:
  Rcvd: 71055 total
  Sent: 0 total
PIMv2 statistics: Sent/Received
  Total: 0/0, 0 checksum errors, 0 format errors
  Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0,  Hellos: 0/0
  Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
  Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
  State-Refresh: 0/0
IGMP statistics: Sent/Received
  Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
  Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
  DVMRP: 0/0, PIM: 0/0
UDP statistics:
  Rcvd: 570437 total, 0 checksum errors, 52919 no port
  Sent: 59593 total, 1565718 forwarded broadcasts
OSPF statistics:
  Rcvd: 0 total, 0 checksum errors
        0 hello, 0 database desc, 0 link state req
        0 link state updates, 0 link state acks
  Sent: 0 total
ARP statistics:
  Rcvd: 2056109 requests, 29511 replies, 245 reverse, 0 other
  Sent: 404933 requests, 726725 replies (35087 proxy), 0 reverse
  Drop due to input queue full: 0
CAM Utilization for ASIC# 0                      Max            Used
                                             Masks/Values    Masks/values
Unicast mac addresses:                       6364/6364        815/815
IPv4 IGMP groups + multicast routes:         1120/1120          1/1
IPv4 unicast directly-connected routes:      6144/6144        742/742
IPv4 unicast indirectly-connected routes:    2048/2048        253/253
IPv4 policy based routing aces:               442/442          12/12
IPv4 qos aces:                                512/512          21/21
IPv4 security aces:                           954/954          35/35
Note: Allocation of TCAM entries per feature uses
a complex algorithm. The above information is meant
to provide an abstract view of the current TCAM utilization
UG-GW-CORE#sh controllers cpu-interface
ASIC    Rxbiterr   Rxunder    Fwdctfix   Txbuflos   Rxbufloc   Rxbufdrain
ASIC0     0          0          0          0          0          0
ASIC1     0          0          0          0          0          0
ASIC2     0          0          0          0          0          0
HOL Fix Counts
No Fixes:          0 Added:          0 In Use:          0 Both:          0
CPU Heartbeat Statistics
Tx Success Tx Fail    1st Thr    2nd Thr    Unthr      RetryCtMax
   3209252          0          0          0          0          1
Rx Delay
         0          1          2          3          4
   3209252          0          0          0          0
AddlDelay AdvanceCnt
         0          0
Rx Retries by RetryCount
         0          1          2          3          4          5          6
   3209252          0          0          0          0          0          0
         7          8          9
         0          0          0
AddlRetry
cpu-queue-frames  retrieved  dropped    invalid    hol-block  stray
rpc               3382904    0          0          0          0
stp               2330649    0          0          0          0
ipc               189710     0          0          0          0
routing protocol  5229189    0          0          0          0
L2 protocol       387206     0          0          0          0
remote console    0          0          0          0          0
sw forwarding     423435     0          0          0          0
host              1080957    0          0          0          0
broadcast         1384772    0          0          0          0
cbt-to-spt        0          0          0          0          0
igmp snooping     669364     0          0          0          0
icmp              6          0          0          0          0
logging           0          0          0          0          0
rpf-fail          0          0          0          0          0
dstats            0          0          0          0          0
cpu heartbeat     3209323    0          0          0          0
cpu-queue         static inuse static added
rpc               0            0
stp               0            0
ipc               0            0
routing protocol  0            0
L2 protocol       0            0
remote console    0            0
sw forwarding     0            0
host              0            0
broadcast         0            0
cbt-to-spt        0            0
igmp snooping     0            0
icmp              0            0
logging           0            0
rpf-fail          0            0
dstats            0            0
cpu heartbeat     0            0
Supervisor ASIC receive-queue parameters
queue 0 maxrecevsize 7E0 pakhead 4CD732C paktail 4D22518
queue 1 maxrecevsize 7E0 pakhead 47A0E2C paktail 47C5A80
queue 2 maxrecevsize 7E0 pakhead 4DCC0E0 paktail 4DCB9A8
queue 3 maxrecevsize 7E0 pakhead 5416754 paktail 54129F8
queue 4 maxrecevsize 7E0 pakhead 4F0EB60 paktail 4F0E428
queue 5 maxrecevsize 7E0 pakhead 53C08DC paktail 53CEC40
queue 6 maxrecevsize 7E0 pakhead 53E39F4 paktail 53E3658
queue 7 maxrecevsize 7E0 pakhead 53183F4 paktail 5307C78
queue 8 maxrecevsize 7E0 pakhead 5331D14 paktail 53315DC
queue 9 maxrecevsize 7E0 pakhead 518450C paktail 518450C
queue A maxrecevsize 7E0 pakhead 5166EC4 paktail 516678C
queue B maxrecevsize 7E0 pakhead 541CDA8 paktail 541CA0C
queue C maxrecevsize 7E0 pakhead 5190D98 paktail 51A647C
queue D maxrecevsize 7E0 pakhead 5180A08 paktail 518402C
queue E maxrecevsize 0 pakhead 0 paktail 0
queue F maxrecevsize 7E0 pakhead 5151CEC paktail 5151950
UG-GW-CORE#sh platform tcam utilization
