Warning message
cisco VOIP cue MWI light not turning on
Answered Question
Jan 27th, 2014
We have a running CME - CUE system, people can leave and listen voicemail without any problem, but voice message indicator on phones not working. It is always off. CME-CUE config and CCSIP debug are attached . Can you please check and advise.
se-10-2-3-2# sh ccn subsystem sip
SIP Gateway:                            10.2.3.1
SIP Port Number:                        5060
DTMF Relay:                             sip-notify,sub-notify
MWI Notification:                       unsolicited
MWI Envelope Info:                      disabled
Transfer Mode:                          bye-also
SIP RFC Compliance:                     Pre-RFC3261
Thank you
Correct Answer by Nadeem Ahmed about 3 years 6 months ago
or best you can use Unsolicited method this most reliable one
Config to be done on CUE
ccn subsystem sip
gateway address 10.2.3.1
mwi sip unsolicited
end
CME
sip-ua
mwi-server ipv4: expires 3600 port 5060 transport udp unsolicited
In this case you do not require MWI dn which have configured in CME,remove it and add above in CME and CUE
ephone-dn  60
number 778... no-reg primary
mwi on
ephone-dn  61
number 779... no-reg primary
mwi off
first try above which i have suggested if didn't work add this one, this will work
Br,
Nadeem
Please rate all useful post.
Overall Rating: 5 (1 ratings)
Nadeem Ahmed Mon, 01/27/2014 - 12:09
  • Cisco Employee,
Hello Umit
Missed this config
sip-ua
mwi-server ipv4:
and check thenm try delete all the previous messages ie unread from the phones then left the VM to the phones and check the MWI is working or not, collect the debug again.
Br,
Nadeem
Correct Answer
Nadeem Ahmed Mon, 01/27/2014 - 12:24
  • Cisco Employee,
ccn subsystem sip
mwi sip unsolicited
end
CME
sip-ua
ephone-dn  60
mwi on
ephone-dn  61
mwi off
Br,
Nadeem
xlhardwarestore Mon, 01/27/2014 - 13:13
Thanks Nadeem,
Removing dn numbers and correcting CUE-CME config fixed the problem. I have one last question for same configuration:
We want all outgoing calls look like made only from one number , means phone receivers
should see only single/same number although we have more than one PSTN numbers, how can we achieve this,  should I start new discussion for that?
Thanks for your help
xlhardwarestore Tue, 01/28/2014 - 10:49
Hi Nadeem,
Let's say I have 5 POTS numbers ending with: (connected to FXO ports)
1234
4321
2341
4123
4211
Whenever we call outside using one of these POTS lines, I want all call receivers to see a single/same company phone number. (Let's say 4211, our company main number) I don't want other numbers to be shown to other side even we call through one of them. I have tried a few things but didn't work, can you please help. CME config is attached at my original post.
Related Content
