Warning message
Slow copying speed from server
Jan 27th, 2014
Hi.
We have a Windows 2012 server connected via 4 ethernet to 4 ports on a 3750 CISCO switch.  We have in that same switch a 1000fx SFP port connected to a iscsi target provided to us by our ISP.  We are trying to utilise the target for server backups.  The 4 ports are in a configuration of a LACP port channel, although there is only target and source, so this ight be a mute point.  The issue we are experiencing happens if its one dedicated port, or if its just one port channel.
The issue is the backup speed, as reported by Windows is extremely slow.  the switch Network Management System (PRTG) shows the port channel operating at 100M, however the results from Windows in terms of speed is all over the place.  Attached below is the speeds we are getting from the windows copy service on the copy (in this example its stalled, and will come back again after a few minutes, and then sit at about 10MB/s - it starts at about 100MB/s).  I thought it could be a buffer issue on the switch, but the port channel connecting to the server has no errors, and nor does the gig link to the iscsi target.  Im a bit confused - I dont know if its the switch or the server, although I thought I would start with the switch.  CEF is not enabled, but then its all on the same VLAN so didnt think that was necessary.  Switch CPU is fine (doesnt budge).
Any help would be much appreciated.
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0016.46c3.6085 (bia 0016.46c3.6085)
  Description: Backup_Port_Channel_1
  MTU 1500 bytes, BW 400000 Kbit, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 38/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Fa1/0/1 Fa1/0/2 Fa1/0/3 Fa1/0/4
  Last input never, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 975
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 59922000 bits/sec, 4945 packets/sec
  5 minute output rate 1343000 bits/sec, 2518 packets/sec
     15121218 packets input, 21555551584 bytes, 0 no buffer
     Received 82075 broadcasts (79043 multicasts)
     0 watchdog, 79043 multicast, 0 pause input
     12049544 packets output, 2902056803 bytes, 0 underruns
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0016.46c3.6081 (bia 0016.46c3.6081)
  Description:Backup_Fibre_Linknet
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 21/255, rxload 1/255
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
  Last input 00:00:00, output 00:00:37, output hang never
  5 minute input rate 1904000 bits/sec, 3628 packets/sec
  5 minute output rate 86268000 bits/sec, 7126 packets/sec
     11047141 packets input, 2667451011 bytes, 0 no buffer
     Received 660835 broadcasts (655049 multicasts)
     0 watchdog, 655049 multicast, 0 pause input
     17927644 packets output, 25902052643 bytes, 0 underruns
Vasilii Mikhail... Tue, 01/28/2014 - 04:02
  • Gold, 750 points or more
Hello, Brad.
It's clear why transfer over Etherchannel can't go over 100M - because LACP is doing load-sharing based on src-dst-MAC (or even in case of IP - they are the same), so the traffic is always using single link in your bundle.
Regarding gaps down from 100M - I guess you could try to capture performance couters for the iSCSI target.
