Warning message
1121 upgrade from 5.2 to 5.5
Jan 27th, 2014
I successfully upgraded the standalone appliance from 5.2 to 5.4 utilizing the upgrade application.  I then tried to upgrade from 5.4 to 5.5 and it ran successfully but after the reboot it doesn't load at all.  Is there a way to boot into a version and restore the configurations from the backup on the device?
Overall Rating: 5 (1 ratings)
edwjames Tue, 01/28/2014 - 05:33
  • Silver, 250 points or more
Hi Cheryl,
Please open a TAC case for this.
**Share your knowledge. It’s a way to achieve immortality.
--Dalai Lama**
Please Rate if helpful.
Ed
Cheryl Krueger Tue, 01/28/2014 - 10:54
Thank you Ed.  I ended up opening a TAC right after I created the question.  I am working with someone now to restore it.
Javier Henderson Tue, 01/28/2014 - 17:46
  • Cisco Employee,
For the benefit of others reading this thread: Cheryl Lee ran into bug CSCum04132 which I filed recently, there is a workaround which involves re-installing the MBR using a CentOS or Red Hat installation disc in Linux recovery mode. The step by step instructions are in the notes for the bug I just mentioned.
Javier Henderson
Cisco Systems
