BAT for CUCM 4.1 Updating Call Forward
Answered Question
Jan 28th, 2014
I'm working on an old CUCM 4.1 and I need to use BAT to update the forward settings on several lines.  I really don't want to do this one by one.  However, I need to forward line one to line two which is the same extension but in different partitions.  So that I can use BAT to do this does anyone know if I can use a wildcard such as XXXX or 5XXX in the forward destination?  Will it use the current DN for the forward?
Correct Answer by Jaime Valencia about 3 years 6 months ago
No, you need to type in numeric values only
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
VON CLAWSON Tue, 01/28/2014 - 09:54
Darn, I was hoping that wasn't the answer.  Would have saved me a lot of work.  Oh well.
Thanks for your help.
Related Content
