UCS,CUCM and MS Exchange
Jan 29th, 2014
Apologies for noob question but is it possible to run CUCM & MS Exchange on the same UCS C server? Is there a sizing tool that will help me spec this?
Rich
Overall Rating: 4 (2 ratings)
richb1971 Wed, 01/29/2014 - 06:14
Cheers Manish. Does that cater for MS Exchange too?
Manish Gogna Wed, 01/29/2014 - 06:19
  • Cisco Employee,
Hi Rich,
The sizing tool will only cover Unified Communication applications.
Manish
richb1971 Wed, 01/29/2014 - 06:25
Thanks for links Manish. Unfortunately none of them help much with MS Exchange.
Useful stuff tho
Jaime Valencia Wed, 01/29/2014 - 07:03
  • Cisco Employee,
  • Hall of Fame,
    2011
If you want/expect a link that covers whether a particular app is supported on UCS, there isn't one. You won't find a doc explaining on which scenarios Exchange will work and how to size, etc.
We provide guidelines for ALL the 3rd party apps, only special case which has particular considerations is the 6K as which set of applications can be deployed is limited.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
