01-29-2014 09:30 AM - edited 03-04-2019 10:12 PM
Hello everyone!
We are going to implement VRRP in our organization. Currently we have just 1 router with peer-to-peer subnet with our ISP
Say, we have an ip address of Gi0/1 1.1.1.1 and ISP has 1.1.1.2 (in real life these are public IP addresses) and we use them to statically route our public IP addresses to the ISP
Now what we plan to do is to configure VRRP on this interface (gi0/1) and the second router's interface (gi0/1). The question is that if we are going to have our 1.1.1.1 IP as a virtual IP address, which addresses can I use for the interfaces on both routers? Can it be just any IP address from a single subnet or anything else?
Thank you!
Solved! Go to Solution.
01-29-2014 10:07 AM
No it won't work. The group doesn't try to come up because of the error:
R2(config-if)#
*Mar 1 00:04:58.751: VRRP: vrrp_interface_state: Fa0/0 is Up
*Mar 1 00:04:58.751: VRRP: vrrp_swif_comingup: Fa0/0 now Up
*Mar 1 00:04:58.751: VRRP: Grp 10 Event - Interface UP
*Mar 1 00:04:58.751: VRRP: Grp 10 not ready to start
*Mar 1 00:04:58.755: VRRP: vrrp_interface_state: Fa0/0 is Up
*Mar 1 00:04:58.755: VRRP: vrrp_swif_comingup: Fa0/0 now Up
*Mar 1 00:04:58.759: VRRP: Grp 10 Event - Interface UP
*Mar 1 00:04:58.759: VRRP: Grp 10 not ready to start
R2(config-if)#
If I change it to the same subnet (real address is 192.168.12.2 and vIP is 192.168.12.50), the group comes up:
*Mar 1 00:06:03.647: %VRRP-6-STATECHANGE: Fa0/0 Grp 10 state Disable -> Init
*Mar 1 00:06:03.647: VRRP: vrrp_interface_state: Fa0/0 is Up
*Mar 1 00:06:03.647: VRRP: Grp 10 Event - Interface UP
HTH,
John
*** Please rate all useful posts ***
01-29-2014 09:46 AM
You have to use something that is in the subnet of the virtual address that you're using. So technically, you'd need at a minimum a /29 from your ISP to use vrrp on the wan side.
VRRP will complain, as will HSRP, if you try to use a subnet different from the physical addresses:
FastEthernet0/0 - Group 10
State is Init
Virtual IP address is 192.168.30.2 (wrong subnet for this interface)
Virtual MAC address is 0000.5e00.010a
Advertisement interval is 1.000 sec
Preemption enabled
Priority is 100
Master Router is unknown, priority is unknown
Master Advertisement interval is unknown
Master Down interval is unknown
HTH,
John
01-29-2014 09:57 AM
Thank you John,
It will complain, as I can see, but will it work?
01-29-2014 10:07 AM
R2(config-if)#
R2(config-if)#
HTH,
John
01-29-2014 10:17 AM
Thank you, John!
