Warning message
downloads cutoff
Jan 29th, 2014
I've been noticing intermittent problems with downloading. Internet access is fine, but I've confirmed that some clients have problems downloading from the internet. For example a fiel is in the process of downloading then it will just cutoff and cancel the download, sometimes it wont. There is nothing that I can think of that would cause this as there have been no network changes to anything that would cause this. Usually its with larger downloads that it will happen, but I've also seen it with smaller ones (1-2mb etc) as well. Any ideas where to begin?
Thanks.
mvsheik123 Wed, 01/29/2014 - 13:05
  • Gold, 750 points or more
downloading from the internet -> You  need to look into multiple things here.
a) Could be the remote servers issue,
b) Your bandwidth usage when the disconnect happens.
c) You notice any issues with you internet service when the disconnect occurs? or any drops/errors on the service provider hand off?
d) Any other devices in the path (PC --> Internet) regestering any errors?
Thx
MS
tolinrome tolinrome Wed, 01/29/2014 - 13:07
I tried different remote servers and same issue, so it cant be that.
Still determining this.
Still determing.
Everything else in the path is fine.
paul driver Wed, 01/29/2014 - 14:19
  • Green, 3000 points or more
Hello
You say nothing has changed,So have you check with you service providor regards any link issues and have you tested
your link speed if applicable to see that you are getting the specifed CIR you are paying for?
http://www.speedtest.net/
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
