Warning message
Authentication passed - authorization failed - IOS bug?
Jan 29th, 2014
Bear with me as I cut/paste information gathered while trying to find a solution to our agency issue.
Platforms:  Cisco 2821 Router  & Cisco 2911 Router
Will provide IOS level/revision at the start of each segment.
Problem discussion:  We use TACACS+ to authenticate end-users at remote locations and depending on which group they belong will determine if they have Internet access or Intranet Only access.
2821 with IOS: c2800nm-advsecurityk9-mz.124-20.T2
Has no issue authenticating and authorizing end-users.  However, with the 200+ remote sites we have noticed an issue with auth cache not clearning correctly and we are spending a lot of time clearing IP addresses from the router manually.  Thus, the hunt for an updated IOS that might be better suited and alleviate the cache clear issue.   We have tested two routers with IOS c2800nm-advsecurityk9-mz.151-4.M7 and have not had to clear auth cache from these routers in over a month using ACS server 4.2  Now, here's where things get interesting.   We are currently using ACS 4.2, but have two new 5.4 ACS appliances that will work in conjuntion with AD for end-user authentication (leaving authorization to ACS).  The two routers with 15.1 code will not work.  They authenticate just fine, but fail during authorization.  I can load the old IOS on the router with the same exact config and it will work just fine.  I've tried  c2800nm-advsecurityk9-mz.150-1.M10 code and it does indeed work (authorization), but we still have the same issue with clearing auth cache IP addresses.
Here's the working 15.0 code debug:  (tacacs/aaa authentication and authorization) using ACS 5.4
[Debug TACACS & AAA authentication and authorization] <I've changed the workstation IP address to something other than production>
Jan 29 13:47:28.361: AAA: parse name=GigabitEthernet0/1 idb type=-1 tty=-1
Jan 29 13:47:28.361: AAA: name=GigabitEthernet0/1 flags=0x15 type=22 shelf=0 slot=0 adapter=0 port=1 channel=0
Jan 29 13:47:28.361: AAA: parse name=<no string> idb type=-1 tty=-1
Jan 29 13:47:28.361: AAA/MEMORY: create_user (0x45667B40) user='NULL' ruser='NULL' ds0=0 port='GigabitEthernet0/1' rem_addr='192.168.1.11' authen_type=ASCII service=LOGIN priv=0 initial_task_id='0', vrf= (id=0)
Jan 29 13:47:28.361: AAA/AUTHEN/START (3899021442): port='GigabitEthernet0/1' list='default' action=LOGIN service=LOGIN
Jan 29 13:47:28.361: AAA/AUTHEN/START (3899021442): found list default
Jan 29 13:47:28.361: AAA/AUTHEN/START (3899021442): Method=LOCAL
Jan 29 13:47:28.365: AAA/AUTHEN (3899021442): status = GETUSER
Jan 29 13:47:28.365: AAA/AUTHEN/CONT (3899021442): continue_login (user='(undef)')
Jan 29 13:47:28.365: AAA/AUTHEN/CONT (3899021442): Method=LOCAL
Jan 29 13:47:28.365: AAA/AUTHEN(3899021442): User not found, emulating local-override
Jan 29 13:47:28.365: AAA/AUTHEN (3899021442): status = ERROR
Jan 29 13:47:28.365: AAA/AUTHEN/START (3776193362): port='GigabitEthernet0/1' list='' action=LOGIN service=LOGIN
Jan 29 13:47:28.365: AAA/AUTHEN/START (3776193362): Restart
Jan 29 13:47:28.365: AAA/AUTHEN/START (3776193362): Method=TACACS_GRP1 (tacacs+)
Jan 29 13:47:28.365: TAC+: send AUTHEN/START packet ver=192 id=-518773934
Jan 29 13:47:28.365: TAC+: Using default tacacs server-group "TACACS_GRP1" list.
Jan 29 13:47:28.365: TAC+: Opening TCP/IP to 192.168.1.2/49 timeout=2
Jan 29 13:47:28.365: TAC+: Opened TCP/IP handle 0x470E8E58 to 192.168.1.2/49
Jan 29 13:47:28.365: TAC+: 10.2.22.20 (3776193362) AUTHEN/START/LOGIN/ASCII queued
Jan 29 13:47:28.565: TAC+: (3776193362) AUTHEN/START/LOGIN/ASCII processed
Jan 29 13:47:28.565: TAC+: ver=192 id=-518773934 received AUTHEN status = GETPASS
Jan 29 13:47:28.565: AAA/AUTHEN (3776193362): status = GETPASS
Jan 29 13:47:28.565: AAA/AUTHEN/CONT (3776193362): continue_login (user='testuser')
Jan 29 13:47:28.565: AAA/AUTHEN (3776193362): Method=TACACS_GRP1 (tacacs+)
Jan 29 13:47:28.565: TAC+: send AUTHEN/CONT packet id=-518773934
Jan 29 13:47:28.565: TAC+: 192.168.1.2 (3776193362) AUTHEN/CONT queued
Jan 29 13:47:28.765: TAC+: (3776193362) AUTHEN/CONT processed
Jan 29 13:47:28.765: TAC+: ver=192 id=-518773934 received AUTHEN status = PASS
Jan 29 13:47:28.765: AAA/AUTHEN (3776193362): status = PASS
Jan 29 13:47:28.765: TAC+: Closing TCP/IP 0x470E8E58 connection to 192.168.1.2/49
Jan 29 13:47:28.765: GigabitEthernet0/1 AAA/AUTHOR/HTTP (2372033975): Port='GigabitEthernet0/1' list='default' service=AUTH-PROXY
Jan 29 13:47:28.765: AAA/AUTHOR/HTTP: GigabitEthernet0/1 (2372033975) user='testuser'
Jan 29 13:47:28.765: GigabitEthernet0/1 AAA/AUTHOR/HTTP (2372033975): send AV service=auth-proxy
Jan 29 13:47:28.765: GigabitEthernet0/1 AAA/AUTHOR/HTTP (2372033975): send AV cmd*
Jan 29 13:47:28.765: GigabitEthernet0/1 AAA/AUTHOR/HTTP(2372033975): found list "default"
Jan 29 13:47:28.765: GigabitEthernet0/1 AAA/AUTHOR/HTTP (2372033975): Method=TACACS_GRP1 (tacacs+)
Jan 29 13:47:28.765: AAA/AUTHOR/TAC+: (2372033975): user=he00020
Jan 29 13:47:28.765: AAA/AUTHOR/TAC+: (2372033975): send AV service=auth-proxy
Jan 29 13:47:28.765: AAA/AUTHOR/TAC+: (2372033975): send AV cmd*
Jan 29 13:47:28.765: TAC+: using previously set server 192.168.1.2 from group TACACS_GRP1
Jan 29 13:47:28.765: TAC+: lookup 192.168.1.2 in DNS local cache
Jan 29 13:47:28.765: TAC+: Using default tacacs server-group "TACACS_GRP1" list.
Jan 29 13:47:28.765: TAC+: Opening TCP/IP to 192.168.1.2/49 timeout=2
Jan 29 13:47:28.765: TAC+: Opened TCP/IP handle 0x470E24F4 to 192.168.1.2/49
Jan 29 13:47:28.765: TAC+: 192.168.1.2 (2372033975) AUTHOR/START queued
Jan 29 13:47:28.965: TAC+: (2372033975) AUTHOR/START processed
Jan 29 13:47:28.965: TAC+: (-1922933321): received author response status = PASS_ADD
Jan 29 13:47:28.965: TAC+: Closing TCP/IP 0x470E24F4 connection to 192.168.1.2/49
Jan 29 13:47:28.965: TAC+: Received Attribute "priv-lvl=15"
Jan 29 13:47:28.965: TAC+: Received Attribute "proxyacl#1=permit ip any any"
Jan 29 13:47:28.965: AAA/AUTHOR (2372033975): Post authorization status = PASS_ADD
Jan 29 13:47:31.969: %AP-6-AUTH_PROXY_AUDIT_START: initiator (192.168.1.11) start
This is the same router with the same config but updated IOS (15.1) and using ACS 5.4
[Debug TACACS & AAA authentication and authorization] FAILED TEST
Jan 29 15:06:27.726: AAA/BIND(00000010): Bind i/f
Jan 29 15:06:27.730: AAA/AUTHEN/AUTH-PROXY (00000010): Pick method list 'default'
Jan 29 15:06:27.730: TPLUS: Queuing AAA Authentication request 16 for processing
Jan 29 15:06:27.730: TPLUS: processing authentication start request id 16
Jan 29 15:06:27.730: TPLUS: Authentication start packet created for 16(testuser)
Jan 29 15:06:27.730: TPLUS: Using server 192.168.1.2
Jan 29 15:06:27.734: TPLUS(00000010)/0/NB_WAIT/47823D9C: Started 2 sec timeout
Jan 29 15:06:27.734: TPLUS(00000010)/0/NB_WAIT: socket event 2
Jan 29 15:06:27.734: TPLUS(00000010)/0/NB_WAIT: wrote entire 27 bytes request
Jan 29 15:06:27.734: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:27.734: TPLUS(00000010)/0/READ: Would block while reading
Jan 29 15:06:27.742: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:27.742: TPLUS(00000010)/0/READ: read entire 12 header bytes (expect 16 bytes data)
Jan 29 15:06:27.742: TPLUS(00000010)/0/READ: read entire 28 bytes response
Jan 29 15:06:27.742: TPLUS(00000010)/0/47823D9C: Processing the reply packet
Jan 29 15:06:27.742: TPLUS: Received authen response status GET_PASSWORD (8)
Jan 29 15:06:27.742: TPLUS: Queuing AAA Authentication request 16 for processing
Jan 29 15:06:27.742: TPLUS: processing authentication continue request id 16
Jan 29 15:06:27.742: TPLUS: Authentication continue packet generated for 16
Jan 29 15:06:27.742: TPLUS(00000010)/0/WRITE/47823D9C: Started 2 sec timeout
Jan 29 15:06:27.742: TPLUS(00000010)/0/WRITE: wrote entire 27 bytes request
Jan 29 15:06:27.766: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:27.766: TPLUS(00000010)/0/READ: read entire 12 header bytes (expect 6 bytes data)
Jan 29 15:06:27.766: TPLUS(00000010)/0/READ: read entire 18 bytes response
Jan 29 15:06:27.770: TPLUS(00000010)/0/47823D9C: Processing the reply packet
Jan 29 15:06:27.770: TPLUS: Received authen response status PASS (2)
Jan 29 15:06:27.770: AAA/AUTHOR (0x10): Pick method list 'default'
Jan 29 15:06:27.770: TPLUS: Queuing AAA Authorization request 16 for processing
Jan 29 15:06:27.770: TPLUS: processing authorization request id 16
Jan 29 15:06:27.770: TPLUS: Sending AV service=auth-proxy
Jan 29 15:06:27.770: TPLUS: Sending AV protocol=ip
Jan 29 15:06:27.770: TPLUS: Authorization request created for 16(testuser)
Jan 29 15:06:27.770: TPLUS: using previously set server 192.168.1.2 from group TACACS_GRP1
Jan 29 15:06:27.774: TPLUS(00000010)/0/NB_WAIT/47823D9C: Started 2 sec timeout
Jan 29 15:06:27.774: TPLUS(00000010)/0/NB_WAIT: socket event 2
Jan 29 15:06:27.774: TPLUS(00000010)/0/NB_WAIT: wrote entire 58 bytes request
Jan 29 15:06:27.774: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:27.774: TPLUS(00000010)/0/READ: Would block while reading
Jan 29 15:06:27.778: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:27.778: TPLUS(00000010)/0/READ: read 0 bytes
Jan 29 15:06:29.774: TPLUS(00000010)/0/READ/47823D9C: timed out
Jan 29 15:06:29.774: TPLUS: Sending AV service=auth-proxy
Jan 29 15:06:29.774: TPLUS: Sending AV protocol=ip
Jan 29 15:06:29.774: TPLUS: Authorization request created for 16(testuser)
Jan 29 15:06:29.774: TPLUS(00000010)/0/READ/47823D9C: timed out, clean up
Jan 29 15:06:29.774: TPLUS(00000010)/0/47823D9C: Processing the reply packet - FAIL
Jan 29 15:06:29.802: AAA/AUTHEN/AUTH-PROXY (00000010): Pick method list 'default'
Jan 29 15:06:29.806: TPLUS: Queuing AAA Authentication request 16 for processing
Jan 29 15:06:29.806: TPLUS: processing authentication start request id 16
Jan 29 15:06:29.806: TPLUS: Authentication start packet created for 16(testuser)
Jan 29 15:06:29.806: TPLUS: Using server 192.168.1.2
Jan 29 15:06:29.810: TPLUS(00000010)/0/NB_WAIT/478F7640: Started 2 sec timeout
Jan 29 15:06:29.810: TPLUS(00000010)/0/NB_WAIT: socket event 2
Jan 29 15:06:29.810: TPLUS(00000010)/0/NB_WAIT: wrote entire 27 bytes request
Jan 29 15:06:29.810: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:29.810: TPLUS(00000010)/0/READ: Would block while reading
Jan 29 15:06:29.814: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:29.814: TPLUS(00000010)/0/READ: read entire 12 header bytes (expect 16 bytes data)
Jan 29 15:06:29.814: TPLUS(00000010)/0/READ: read entire 28 bytes response
Jan 29 15:06:29.814: TPLUS(00000010)/0/478F7640: Processing the reply packet
Jan 29 15:06:29.814: TPLUS: Received authen response status GET_PASSWORD (8)
Jan 29 15:06:29.818: TPLUS: Queuing AAA Authentication request 16 for processing
Jan 29 15:06:29.818: TPLUS: processing authentication continue request id 16
Jan 29 15:06:29.818: TPLUS: Authentication continue packet generated for 16
Jan 29 15:06:29.818: TPLUS(00000010)/0/WRITE/478F7640: Started 2 sec timeout
Jan 29 15:06:29.818: TPLUS(00000010)/0/WRITE: wrote entire 27 bytes request
Jan 29 15:06:29.834: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:29.834: TPLUS(00000010)/0/READ: read entire 12 header bytes (expect 6 bytes data)
Jan 29 15:06:29.834: TPLUS(00000010)/0/READ: read entire 18 bytes response
Jan 29 15:06:29.838: TPLUS(00000010)/0/478F7640: Processing the reply packet
Jan 29 15:06:29.838: TPLUS: Received authen response status PASS (2)
Jan 29 15:06:29.838: AAA/AUTHOR (0x10): Pick method list 'default'
Jan 29 15:06:29.838: TPLUS: Queuing AAA Authorization request 16 for processing
Jan 29 15:06:29.838: TPLUS: processing authorization request id 16
Jan 29 15:06:29.838: TPLUS: Sending AV service=auth-proxy
Jan 29 15:06:29.838: TPLUS: Sending AV protocol=ip
Jan 29 15:06:29.838: TPLUS: Authorization request created for 16(testuser)
Jan 29 15:06:29.838: TPLUS: using previously set server 192.168.1.2 from group TACACS_GRP1
Jan 29 15:06:29.842: TPLUS(00000010)/0/NB_WAIT/478F7640: Started 2 sec timeout
Jan 29 15:06:29.842: TPLUS(00000010)/0/NB_WAIT: socket event 2
Jan 29 15:06:29.842: TPLUS(00000010)/0/NB_WAIT: wrote entire 58 bytes request
Jan 29 15:06:29.842: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:29.842: TPLUS(00000010)/0/READ: Would block while reading
Jan 29 15:06:29.846: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:29.846: TPLUS(00000010)/0/READ: read 0 bytes
Jan 29 15:06:31.838: TPLUS(00000010)/0/READ/478F7640: timed out
Jan 29 15:06:31.838: TPLUS: Sending AV service=auth-proxy
Jan 29 15:06:31.838: TPLUS: Sending AV protocol=ip
Jan 29 15:06:31.838: TPLUS: Authorization request created for 16(testuser)
Jan 29 15:06:31.838: TPLUS(00000010)/0/READ/478F7640: timed out, clean up
Jan 29 15:06:31.838: TPLUS(00000010)/0/478F7640: Processing the reply packet - FAIL
Jan 29 15:06:31.898: AAA/AUTHEN/AUTH-PROXY (00000010): Pick method list 'default'
Jan 29 15:06:31.902: TPLUS: Queuing AAA Authentication request 16 for processing
Jan 29 15:06:31.902: TPLUS: processing authentication start request id 16
Jan 29 15:06:31.902: TPLUS: Authentication start packet created for 16(testuser)
Jan 29 15:06:31.902: TPLUS: Using server 192.168.1.2
Jan 29 15:06:31.906: TPLUS(00000010)/0/NB_WAIT/478F2274: Started 2 sec timeout
Jan 29 15:06:31.906: TPLUS(00000010)/0/NB_WAIT: socket event 2
Jan 29 15:06:31.906: TPLUS(00000010)/0/NB_WAIT: wrote entire 27 bytes request
Jan 29 15:06:31.906: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:31.906: TPLUS(00000010)/0/READ: Would block while reading
Jan 29 15:06:31.910: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:31.910: TPLUS(00000010)/0/READ: read entire 12 header bytes (expect 16 bytes data)
Jan 29 15:06:31.910: TPLUS(00000010)/0/READ: read entire 28 bytes response
Jan 29 15:06:31.910: TPLUS(00000010)/0/478F2274: Processing the reply packet
Jan 29 15:06:31.910: TPLUS: Received authen response status GET_PASSWORD (8)
Jan 29 15:06:31.910: TPLUS: Queuing AAA Authentication request 16 for processing
Jan 29 15:06:31.914: TPLUS: processing authentication continue request id 16
Jan 29 15:06:31.914: TPLUS: Authentication continue packet generated for 16
Jan 29 15:06:31.914: TPLUS(00000010)/0/WRITE/478F2274: Started 2 sec timeout
Jan 29 15:06:31.914: TPLUS(00000010)/0/WRITE: wrote entire 27 bytes request
Jan 29 15:06:31.930: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:31.930: TPLUS(00000010)/0/READ: read entire 12 header bytes (expect 6 bytes data)
Jan 29 15:06:31.934: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:31.934: TPLUS(00000010)/0/READ: read entire 18 bytes response
Jan 29 15:06:31.934: TPLUS(00000010)/0/478F2274: Processing the reply packet
Jan 29 15:06:31.934: TPLUS: Received authen response status PASS (2)
Jan 29 15:06:31.934: AAA/AUTHOR (0x10): Pick method list 'default'
Jan 29 15:06:31.934: TPLUS: Queuing AAA Authorization request 16 for processing
Jan 29 15:06:31.934: TPLUS: processing authorization request id 16
Jan 29 15:06:31.934: TPLUS: Sending AV service=auth-proxy
Jan 29 15:06:31.934: TPLUS: Sending AV protocol=ip
Jan 29 15:06:31.934: TPLUS: Authorization request created for 16(testuser)
Jan 29 15:06:31.934: TPLUS: using previously set server 192.168.1.2 from group TACACS_GRP1
Jan 29 15:06:31.938: TPLUS(00000010)/0/NB_WAIT/478F2274: Started 2 sec timeout
Jan 29 15:06:31.938: TPLUS(00000010)/0/NB_WAIT: socket event 2
Jan 29 15:06:31.938: TPLUS(00000010)/0/NB_WAIT: wrote entire 58 bytes request
Jan 29 15:06:31.938: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:31.938: TPLUS(00000010)/0/READ: Would block while reading
Jan 29 15:06:31.942: TPLUS(00000010)/0/READ: socket event 1
Jan 29 15:06:31.942: TPLUS(00000010)/0/READ: read 0 bytes
Jan 29 15:06:33.938: TPLUS(00000010)/0/READ/478F2274: timed out
Jan 29 15:06:33.938: TPLUS: Sending AV service=auth-proxy
Jan 29 15:06:33.938: TPLUS: Sending AV protocol=ip
Jan 29 15:06:33.938: TPLUS: Authorization request created for 16(testuser)
Jan 29 15:06:33.938: TPLUS(00000010)/0/READ/478F2274: timed out, clean up
Jan 29 15:06:33.938: TPLUS(00000010)/0/478F2274: Processing the reply packet - FAIL
I've bolded (above) where the problem is and hoping someone much smarter can tell me why it's failing and of course a solution.
I've tried three different routers to eliminate possible hardware issues.  Started fresh with a clean slate with no config and then rebuilt it from scratch.  Same results.
ACS 5.4 authorization reports this:
13011 Invalid TACACS+ request packet - possibly mismatched Shared Secrets
But, before anyone pinpoints that as the issue - it's NOT!  I know what I have typed in and it matches perfectly 100%. Besides, I can take the code to 15.0 with the EXACT same config and it works just fine on ACS 5.4 (and 4.2)
Javier Henderson Wed, 01/29/2014 - 15:31
  • Cisco Employee,
Eric,
Would you be able to capture the traffic between the router and ACS? Ideally you'd get two captures, one with each version of IOS, so we can compare both.
We will need the TACACS+ shared key to decode the packet capture, so you may want to make that something trivial while testing (ie, not something you're using on your production routers).
If you prefer, you can send me the packet capture and shared key directly, and we can summarize our findings here for the benefit of anyone else who might be following this thread.
Javier Henderson
Cisco Systems
Eric Varner Thu, 01/30/2014 - 04:59
Javier,
Not a problem and will get the captures to you ASAP (with non-production shared key).
Thank you.
blenka Thu, 01/30/2014 - 14:48
Please go through the link below may help you to touble shooting for the router with version 15
http://www.cisco.com/en/US/products/ps9911/products_tech_note09186a0080bb8100.shtml#p47
Problem: TACACS+ Auth-Proxy authentication is not working on a router running IOS 15.x from ACS 5.x server
TACACS+ Auth-Proxy authentication is not working on a router that runs Cisco IOS Software Release 15.x from an ACS 5.x server.
Solution
TACACS+ Auth-Proxy is only supported after ACS 5.3 patch 5. Upgrade your ACS 5.x, or use RADIUS for Auth-Proxy.
Eric Varner Fri, 01/31/2014 - 04:59
Thank you for the reply.
We are using an ACS appliance Build ID: B.221  with Patches: 5-4-0-46-5
Not sure what upgrade other than what we are at is available??
Authentications works great! Authorizaton fails!
IOS 15.0.x works fine with the above ACS appliance.
IOS 15.1.x  does not work with the above ACS appliance (authorization fails)
Please check again (I've already sent the packet captures to Javier).
Thank you.
Peter Koltl Fri, 01/31/2014 - 11:48
  • Silver, 250 points or more
  • Community Spotlight Award,
    Member's Choice, March 2016
Do you really use AAA cache feature? What kind of service do you provide with TACACS? Can you post your config?
Eric Varner Fri, 01/31/2014 - 12:36
This is as much as I can provide.
aaa group server tacacs+ TACACS_GRP1
server 10.x.x.x
server 204.x.x.x.x
server 204.x.x.x
aaa authentication login default local group TACACS_GRP1 enable
aaa authentication login local group TACACS_GRP1 enable
aaa authentication login no_tacacs enable
aaa authorization exec default group TACACS_GRP1
aaa authorization commands 15 default if-authenticated
aaa authorization auth-proxy default group TACACS_GRP1
aaa accounting exec default start-stop group TACACS_GRP1
aaa accounting commands 0 default start-stop group TACACS_GRP1
aaa accounting commands 1 default start-stop group TACACS_GRP1
aaa accounting commands 15 default start-stop group TACACS_GRP1
aaa session-id common
dot11 syslog
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name
ip name-server 10.x.x.x
ip auth-proxy auth-proxy-banner http ^Clash:acs.htm ^C
ip auth-proxy auth-proxy-audit
ip auth-proxy inactivity-timer 10
ip auth-proxy absolute-timer 720
ip auth-proxy name ACS http inactivity-time 60 list AUTH_TRAFFIC
ip admission auth-proxy-banner http ^Clash:acs.htm ^C
ip admission auth-proxy-audit
ip admission inactivity-timer 10
ip admission absolute-timer 720
interface GigabitEthernet0/0
description LAN
ip address x.x.x.x 255.255.252.0
ip access-group ACS_USERS in
ip helper-address x.x.x.x
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
ip auth-proxy ACS
ip policy route-map Traffic
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip http server
ip http authentication aaa login-authentication default
ip http authentication aaa exec-authorization default
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip tacacs source-interface GigabitEthernet0/0
ip access-list extended AUTH_TRAFFIC
permit ip 10.0.0.0 0.255.255.255 host x.x.x.x
permit ip 10.0.0.0 0.255.255.255 x.x.x.x. 0.255.255.255
permit ip 10.0.0.0 0.255.255.255 x.x.x.x 0.0.255.255
ip access-list extended ACS_USERS
permit icmp any any
permit udp any eq bootpc any
permit tcp any any established
permit udp any any eq domain
permit tcp any any eq domain
permit udp any any eq snmptrap
permit ip host x.x.x.10 any
permit ip host x.x.x.11 any
permit ip host x.x.x.2 any
permit ip host x.x.x.33 any
permit ip host x.x.x.52 host x.x.x.x
permit ip host x.x.x.50 host x.x.x.x
permit ip host x.x.x.51 host x.x.x.x
permit ip host x.x.x.47 any
permit ip host x.x.x.5 any
permit ip host x.x.x.97 any
permit ip host x.x.x.100 any
permit ip host x.x.x.101 any
permit ip host x.x.x.102 any
permit ip host x.x.x.3 any
permit ip host x.x.x.193 any
permit ip host x.x.x.65 any
permit ip host x.x.x.4 any
permit ip host x.x.x.9 any
permit ip host x.x.x.8 any
deny   ip any any
tacacs-server host 10.x.x.x single-connection
tacacs-server host 204.x.x.x. single-connection
tacacs-server host 204.x.x.x single-connection
tacacs-server directed-request
tacacs-server key 123456
_______
Been using this type config to authenticate/authorize end-users for 10yrs.  Older code will work with ACS 5.4, but 15.1 code will not work.
Eric Varner Mon, 02/03/2014 - 08:00
Need someone from Cisco to repond via PM with a valid e-mail address so I can send the packet captures.
Thank you.
