01-29-2014 10:43 PM - edited 03-16-2019 09:30 PM
Hi!
I need some help with 3905 SIP phones and CME 9.1 (2911 Router):
* I read that conference in this phone is supported, but I can't find how to set the conference up. There isn't a dedicated key for conferencing and when I'm in a call there is no options available in the menu.
* For some reason, the phone loses registration with the CME and the only way to get it back is unplugging and plugging it back in to the switch.
Even if I restart the Router, the phone still shows its label and if I off-hook it, strangely gives a dial tone. When the Router is back the phone don't try to register again until it's restarted. ¿Isn't there a keep alive for registration with the CME?
Thanks for your help!
Best regards.
P.S. 3905 firmware v9.4.1
01-29-2014 11:10 PM
Hi Victor,
Can you try the couple of suggestions from the following thread, it includes both the phone locking up as well as conference issue
https://supportforums.cisco.com/thread/2220233
Manish
01-30-2014 08:47 AM
Hi Manish,
I had read that post before, but the "phone locking" wasn't resolved. I've read there is a similar issue with traditional CUCM, where the 3905 phone doesn't realize that the CUCM are gone and therefore doesn't switch to SRST mode until it's restarted. I didn't find a workaround either.
And the issue with the conference is more simple: I just don't know how to start a conference in the 3905.
Any help? Regards.
