2 Isps, 2 Routers Redundancy
Jan 30th, 2014
Hey guys!
thanks for reading my post.
i have two routers, one is a 3800 and one is a 2901.
the 2901 is connected to an isp on a leased line with a /27 address pool and runs another 2 adsl lines on a vdsl hwics for users internet browsing.
the second is connected to a second isp on a leased line with a /27 address pool and runs a cable l2tp dialers as well for users internet browsing.
both firewalls are not directly connected, but connected through a firewall.
what i want to do is basically use those routers to backup eachother. preferable through the firewalls for the security, because i don't want to create any other bridging.
now statically - that's a lot of mess and configuration.
do you have any offers for me?
i can add wics and connect those together if needed.
i appreicate any help.
smitesh kharecha Mon, 03/10/2014 - 04:39
  • Silver, 250 points or more
By backup, do you mean one active at a time and second one only active once primary has failed ?
If this is your requirement, HSRP or VRRP can be used.
You might also be interested in GLBP by the way.
HTH,
Smitesh Kharecha
PS: Please rate helpful posts.
