ACE 4710 - Different default routes in Contexts
comtec.ops
Hi all,
     I am hoping this is a simple question with a simple answer. I am considering redsigning the way our current ACE4710 are deployed in our network from a single context to multiple contexts. So the simple question is - in each destinct context is it possible to set a different Default route?
Ryan
Kanwaljeet Singh
Hi Ryan,
Yes you can have a different default route for different contexts.
Kanwal
Kanwaljeet Singh
Hi Ryan,
Kanwal
hi Kanwal
Thanks for the answer. I expected that that would be the case, but wanted it confirmed before I start redesigning the network.
Ryan
Hi Ryan,
You are welcome and here is one link for deployment/design which you might like to look at.
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5719/ps7027/ps8361/guide_c07-572616_ps7027_Products_White_Paper.html
kanwal
