Warning message
CAD 9.0 on UCCX 8.5?
Jan 30th, 2014
Hello Everyone,
I have a question. Is it possible to run CAD version 9.0 on UCCX version 8.5? I installed CAD 9.0 and everytime I start, it talks to UCCX and says version on the server is different, therefore an update must happen. Please advise.
Thank You,
tonyperla Thu, 01/30/2014 - 12:32
  • Silver, 250 points or more
That is correct Hardik, the version of CAD and CAS has to be inline with the version of UCCX that you are running on your server or cluster.  If your UCCX environment is running 8.5 then the agents must run the CAD software associated with that version of 8.5
Tony
Please rate helpful posts!
