Warning message
Dual wan routing question
Jan 30th, 2014
I'm having an issue with my MPLS. I'm not sure the best way to describe it other than an example.
I connect to a website owned by Chrysler.  Sometimes it works, oftentimes  portions of the site do not respond.
My first step is pinging the remote network.  If I get a reply, it is something like  wg.random#.dc.chrysler.com.  If I don't get a reply, I have to wait 10-15 minutes for another server to reply (wg.random#3.dc.chrysler.com).
When I traceroute during a Request timed out, I make it about 4 or 5 hops outside my MPLS router.  My MPLS provider blames it on everyone outside their network.
If I go out my backup ISP provider (Cox fiber), it always works all of the time.
I want to use Cox in 2 situations.  The first is when my MPLS goes down (floating static route).  The second is to send Chrysler traffic out my Cox interface when MPLS to Chrysler fails.
Because there are a ton of destination servers and a large IP range, is it possible to send traffic headed to Chrysler out my Cox interface while keeping all other traffic flowing through my MPLS network?
Jon Marshall Thu, 01/30/2014 - 12:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Matt
Do you know the IP address(es) for the web site ?
Jon
mattshenefield Thu, 01/30/2014 - 12:26
No.  The only way I can determine where they are connecting is with a ping.
They are using a 3rd party to host and I've been unsuccessful in getting the range.  What I do know is that there is a large variance between both the first octect and the second octect.
Jon Marshall Thu, 01/30/2014 - 12:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Matt
Okay, i have never done it but i thought maybe you could use NBAR (to match the URL) together with PBR to direct the traffic out over the secondary link.
So a quick search and i found this thread although you may be able to find others. I can't guarantee it will work but it may be worth a try -
https://supportforums.cisco.com/thread/2051012
Jon
