Warning message
Script variables copy
Answered Question
Jan 30th, 2014
one of my scripts is bad and will not let me delete any lables.  I want to create a new script and would like to find a way to copy all the variables over to the new script.  is ther a way to do this?
thanks
Correct Answer by Anthony Holloway about 3 years 6 months ago
Did you name one of your labels "StartSomething" or do you have leading white space on an otherwise duplicate label name?
https://supportforums.cisco.com/message/4003082#4003082
Unfortunately, there is no supported method to move variable pane data between scripts.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Overall Rating: 5 (1 ratings)
Correct Answer
Anthony Holloway Fri, 01/31/2014 - 03:40
  • Purple, 4500 points or more
Anthony Holloway
