Warning message
Cisco site-to-site VPN behind non cisco VDSL modem
Jan 31st, 2014
I had a working site-to-site between a Cisco 1841 (ios 12.4) and a cisco 876 router (ios 12.3)...
The problem started when the 876 part upgrade to vdsl so I can't use the 876 to connect so now I'm behind an ISP's vDSL modem...
I follow the tempate at
http://www.cisco.com/en/US/tech/tk86/tk89/technologies_configuration_example09186a0080094be1.shtml
and have a site-to-site VPN connection, the only problem is while I can ping and access from 876 to 1841 , I can't ping or access (except for the 876) from 1841 to 876...
I would appreciate any help or hint...
EDIT: I don't know if helps but on 876 I'm using double NAT, didn't switch modem to bridge mode, but since it's a tunnel, I don't think it's an issue...
vlan2 taking an IP of 192.168.254.0 range and modem has 192.168.254.254.
here is the result of "sh ip route"
     10.0.0.0/24 is subnetted, 2 subnets
D       10.10.10.0 [90/2818560] via 10.0.0.2, 01:10:03, Tunnel0
C       10.0.0.0 is directly connected, Tunnel0
C    192.168.254.0/24 is directly connected, Vlan2
S    192.168.2.0/24 is directly connected, Tunnel0
C    192.168.3.0/24 is directly connected, Vlan1
S*   0.0.0.0/0 [254/0] via 192.168.254.254
Also when I issue "sh crypto isakmp sa" I get in src the local IP address
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
83.xxx.xxx.xxx  192.168.254.17  QM_IDLE           2004 ACTIVE
Here is the nat part of 876
crypto map vpnmap1 local-address Vlan2
interface Vlan1
description --- LAN ---
ip address 192.168.3.253 255.255.255.0
ip nat inside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
interface Vlan2
description --- WAN ---
ip address dhcp
ip nat outside
no ip route-cache
crypto map vpnmap1
ip route 192.168.2.0 255.255.255.0 Tunnel0
ip nat inside source route-map NAT interface Vlan2 overload
route-map NAT permit 10
match ip address PAT
match interface Vlan2
ip access-list extended PAT
deny   ip 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 any
permit ip 192.168.254.0 0.0.0.255 any
permit ip 192.168.2.0 0.0.0.255 any
Message was edited by: gerasimos_h
jshojayi Thu, 02/06/2014 - 00:04
The 876 initiating would work since it's initiating. It sounds like you have the peer IP address on the 1841 pointing to the modem the 876 is plugged into. If the modem holds the public IP, it's not going to be able to terminate the VPN session from the 1841. Try enabling bridge mode so that the 876 gets a public IP and then re-initiate from the 1841.
Thank you.
Joe
memmas nanashi Thu, 02/06/2014 - 11:51
Thanks for the answer,
The 876 connects to 1841 to be accurate...
Also I'm trying to avoid bridging the modem, but now I realize that I'm not going to avoid it after all, even after I was so close to the solution...
Related Content
