Warning message
Database Read
Feb 2nd, 2014
Dear
im looking one solution tm my company we have Oracel Database and CUE , we want only read the infomation bills and intgration with UCCX9 .
can you anybody provid me what is the prefect script , best TTS server and solution for this issue .
thanks
Gergely Szabo Mon, 02/03/2014 - 05:28
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
Hi Hassan,
I always say there are only paths to perfection but it can never be reached. One solution might fit perfectly for one customer while the other one might frown upon it.
UCCX 9 is perfectly capable of talking to an Oracle Database (please take a look at the compatibility matrix to ensure the versions are supported).
For a TTS, an external TTS provider (= server) is required. I have tested Nuance, with satisfactory results.
Do you have a specific requirement or plan we can take a look at?
G.
