Mobility on CUCM
Answered Question
Feb 3rd, 2014
Hii,
I activate the Remote destination and Remote Destination Profile for my extension but I want after 4/5 ring on the desk phone the call to be transferred to My Mobile, is working after I checked theEnable Mobile Connect.
The problem is that it rings only 2 times on my desk and it is transferred to my Mobile, from where I can change the nr of rings on the desk Phone?
Th for help
Correct Answer by Carlo Poggiarelli about 3 years 6 months ago
Hi Gabriel.
Check your delay before ring timer on mobile identity configuration page
Carlo
Overall Rating: 5 (1 ratings)
Correct Answer
Carlo Poggiarelli Mon, 02/03/2014 - 00:47
  • Green, 3000 points or more
Hi Gabriel.
Carlo
