Warning message
PoE on SF-300-24P to AIR-AP1231G
I have a problem with switch SF-300-24P and AIR-AP1231G-E-K9.
The AP is working fine in a switch 2960 or 3560, and I want to move it to a new SF-300-24P.
When it is plugged in SF-300, the AP never get boot up , it obtains power, and blinks its leds, its boot process begin, but it get into a loop, and it's never gets boot up.
If I connect a external power supply to AP while it's booting, the AP gets boot up, and then it work's fine. Even, If i unplug the external power, the AP goes on working fine.
You know about this problem ? What I can do ?
BR // JI
I show you cdp of this hardware:
Device ID: AP3
Entry address(es):
  IP address: 192.168.3.82
Platform: cisco AIR-AP1231G-E-K9    ,  Capabilities: Trans-Bridge
Interface: FastEthernet0/8,  Port ID (outgoing port): FastEthernet0
Holdtime : 134 sec
Version :
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JED1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 27-Apr-10 12:58 by alnguyen
advertisement version: 2
Duplex: full
Power drawn: 4.420 Watts
Power Available TLV:
    Power request id: 0, Power management id: 0, Power available: 0, Power management level: 0
Management address(es):
Device ID: sf-300-24p
Entry address(es):
  IP address: 192.168.3.86
Platform: Cisco SF300-24P (PID:SRW224G4P-K9)-VSD,  Capabilities: Switch IGMP
Interface: GigabitEthernet0/1,  Port ID (outgoing port): gi1
Holdtime : 153 sec
Version :
1.3.0.62
Native VLAN: 1
Duplex: full
    Power request id: 0, Power management id: 31980, Power available: 0, Power management level: -1
show cdp neighbors detail
Device-ID: APLINSER1
Advertisement version: 2
Capabilities: TransBridge
Interface: fa23, Port ID (outgoing port): FastEthernet0
Holdtime: 172
Version: Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JED1, RELEASE SOFTWARE (fc3)
Copyright (
Duplex: full
Power drawn: 4420 milliwatts
SysObjectID: 0.0
Addresses:
          IP 192.168.3.80
Tom Watts Fri, 02/07/2014 - 17:21
  • Green, 3000 points or more
Hi Jose, please upgrade software of the switch to 1.3.5.58 then factory default it. I recommend do not use a back up config, config from scratch. This should resolve that.
-Tom
Please mark answered for helpful posts
