Warning message
Incoming policy to match encrypted email
Answered Question
Feb 3rd, 2014
hi,
The action in the default policy is to quarantine Encrypted Messages.
There is a requirement to deliver encrypted messagesfrom a specific Sender ([email protected]) to a Recipient ([email protected])
Created an incoming policy which matches this sender, and Antivirus policy is set to deliver encrypted messages.
how can we restrict this policy to be applicable only for messages from [email protected] to [email protected]
And have any encrypted message from [email protected] to any other recipients to be quarantined
regards
Correct Answer by David Miller about 3 years 6 months ago
You could set up a policy that applies to sender [email protected] where the AV policy for encrypted message is to deliver, and set the X-IronPort-AV header in the AV policy.  Then and create a content filter that applies to that policy that looks for the AV header and if the recipient is not [email protected] then quarantine the message.  I can't remember the value of the X-IronPort-AV header if the message is encrypted but it should be in the logs of in the header of the received message.  Or you could add a subject prefix in the AV settings that is applied when the message is encrypted (default is [WARNING: MESSAGE ENCRYPTED] and look for that subject prefix in the content filter.  Or you could add a custom header in the advanced section of the AV settings and look for that (and remove it if you want to clean things up).
Overall Rating: 5 (1 ratings)
Correct Answer
David Miller Mon, 02/03/2014 - 05:12
