Warning message
Wierd outputs on switches for same etherchannel
Feb 3rd, 2014
Hi all,
Here is my topology:
I  configure LACP channel b/w Switch1 & switch3. The output on the SW3  for "show etherchannel / show etherchannel port-channel" is fine
but it is in appropriate on Sw1. Can someone please let me know where i'm doing wrong or is this a PT bug?
show etherchannel on Sw1:
Switch1#show etherchannel
                Channel-group listing:
Group: 1
Group state = L2                         // Acutally here the output show the protocol type and ports in it also
Switch1#
Switch1#show etherchannel port-channel
Group: 1
                Port-channels in the group:
Port-channel: Po1    (Primary Aggregator)
Age of the Port-channel   = 00d:00h:17m:33s
Logical slot/port   = 2/1       Number of ports = 2
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel
Protocol            =   LACP
Port Security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Fa0/4                       0
  0     00     Fa0/3                       0
Time since last port bundled:    00d:00h:17m:33s    Fa0/3
Switch1#
Here the EC state is not shown. I tried configuring it as active and passive but the output doesn't change.
Whereas the same command when issued on SW3 shows the correct output.
Switch3#show etherchannel
Group: 1
Group state = L2
Ports: 2 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP                                                    //These 3 lines are missing on SW1 output
Switch3#
Switch3#show etherchannel port-channel
Group: 1
Age of the Port-channel   = 00d:00h:53m:16s
Protocol            =   LACP
0     00     Fa0/4    Active             0
  0     00     Fa0/3    Active             0
Time since last port bundled:    00d:00h:20m:06s    Fa0/3
Here the EC state is show correct but not on SW1.
Please put your inputs.
Thanks a lot in advance.
Chandu
