02-03-2014 08:35 AM
Hi all,
I´m trying to install the latest CIAC version, and I´m facing some problems on the configuration phase.
I´m using the following document:
Cisco_Intelligent_Automation_for_Cloud_4.0_Installation_Guide.pdf
Dowloaded from the Cisco portal.
In the page 34 we can found the procedure to install the REX adapter.
The procedure is very confusing, and I´m not able to find where to put the REXAdapter.xml, it points to C:\Rex\Deploy, but the CIAC appliance is based on linux, and I´m not able to find that file on the Portal Server.
Also the adk.zip is missing from CPO Automation packs.
Thanks in advance,
Alex.
Solved! Go to Solution.
02-03-2014 09:55 AM
The 4.0 appliance already has the RexAdapter installed. You can look in the Service Link Adapters list.
02-03-2014 09:55 AM
02-03-2014 07:52 PM
Correct, the appliance runs a Linux operating system and comes with the REX adapter preinstalled.
02-04-2014 02:29 AM
Thanks for the info, seems the documentation needs a detailed review, I´m a newbey on CIAC and it really confusing.
Thanks all for the help.
Alex.
